HP Officejet Pro L7780 All-In-One InkJet Printer Logo
A
Anonymous Posted on Mar 13, 2015
Won't print blue. prints pink instead - HP Officejet Pro L7780 All-In-One InkJet Printer
sahoo_sanjay
Level 3:
Master:
  • HP Master 553 Answers
  • Posted on Mar 13, 2015
sahoo_sanjay
HP Master
Level 3:
Master:
Answers
553
Questions
0
Helped
218784
Points
1676
Dear
Pl. check the ink cart. if refilled or compatible used replace with genuine.
Thanks.
Printer will not print blue, prints pink instead
Blue is made from magenta (pink) and cyan ( sky blue), if your blues are coming out pink then they are missing the cyan component.
In your machine this could be caused by a blockage in the printhead, the cyan cartridge being empty, an electronics fault, a boma pump fault (the squishy black thing on the base of the cartridge). Check your cartridge first - if it feels lighter than the other it is probably empty. Sometimes there is a fault where the entire contents of a cartridge (usually the cyan) can be emptied in a matter of days or less. If the cartridge is unusually empty compared to the other colours - refer it to HP.
Magental background on all prints looking like a pink papr instead of white
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
2answers
I have an HP Photosmart C3180 printer color ink issue. Instead of printing yellow its printing pink. I've cleaned the head multiple times and the ink cartridge is brand new. Please advise. Thanks!
If what you're saying is still the result after cleaning everything up, there must already be something wrong with the printhead because the printheads are the one's that are responsible for the mixture of the ink cartridges.
Try calling HP Tech Support. They might still be able to replace the printheads for you.
Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
k24674
Grand Canyon Tech
Grand Canyon Tech
