Question about La Crosse Technology TX37U-IT 915MHz Wireless Temperature Sensor
Will not display outside temperature even though I changed the battery on both the inside and outside unit
robert
  • 2,534 Answers
Find reset pin hole on base unit. Push in with a paper clip. Pin hole may be in battery compartment.
Posted on Mar 13, 2015
BAR888A -Changed batteries house (1st) & outside unit(2nd.) Now inside unit not receiving signal. Only thing registering is inside temp. Outside unit is also showing temp.
Remove all batteries. Install batteries in outside unit and allow time for it to begin sending temperature. Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit could be defective.
Sep 25, 2018 | Measuring Tools & Sensors
How to change batteries in outdoor sensor for Model 9080u-it
Begin by removing batteries from the inside unit. There should be clear evidence of a battery compartment on the outside unit. Open it and replace the batteries. Allow time for the outside unit to initialize and begin sending data. Install batteries in the inside unit and observe outside temperature display. If nothing happens, the outside unit could be defective.
Apr 16, 2018 | Measuring Tools & Sensors
The outside temp won't show up on my new weather station
  • Remove all batteries
  • Install batteries in outside unit and wait for it to begin sending temperature signal to inside unit.
  • Install batteries in inside unit. You should see outside temperature displayed.
  • If this doesn't work, the outside unit may be defective.
Apr 04, 2018 | Measuring Tools & Sensors
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
I am getting no outside temperature readings on my Watson W-8386 I have changed the batteries on the transponder.
Try removing all batteries, then installing batteries in outside unit and allowing it to initialize and begin sending temperature data. Install batteries in the inside unit and you should see the outside temperature displayed. If not, the outside unit may be defective.
Nov 05, 2017 | Measuring Tools & Sensors
I have a weather station 9N14 V030U and I can't get the outside temperature to program. We just changed the batteries in both units.
  • Install replacement batteries in the outside unit
  • After allowing time for the outside unit to initialize and begin transmitting data, install batteries in the inside unit. You should see the outside temperature displayed.
May 28, 2017 | Measuring Tools & Sensors
Why is my outside temp not registering. I have replaced the batteries
  • Install outside batteries
  • Move from outside to inside at a casual pace to allow time for outside unit to begin sending temperature
  • Install inside batteries. You should see outside temperature displayed
I find that outside temperature display comes and goes depending upon the weather, e.g., Today at 12 pm, the outside temperature is 35 deg F; earlier this morning it was - -. For the last couple of days, the temperature has been - - then suddenly last night it was 28 deg F.
Jan 30, 2017 | Measuring Tools & Sensors
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
La Crosse Technology TX37U-IT 915MHz Wireless Temperature Sensor Logo
1,451 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
robert
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
