Toshiba E-Studio 356 Multifunction Copier Logo
M
Muhammad Ali Posted on Mar 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black Toner Cartridge Not Recognized.?
I got your card copier's paper tray. Toshiba copier repair works in Toshiba copiers can I help you. I have 356 models of Toshiba. The original toner is installed, the machine error appears on the screen. Black Toner ktrydgy Note rykugnzd You can mail me. If they tell you it is no detection code. I like the est-355 0 + 8 copier power on. code: 499 start value : 0 ok detection disabled. plz help?
  • Copyworld OfficeEquipment
    No sir,
    Actually toshiba copier e-studio 307,
    Black toner cartridge open front cover.
    But this machine using original cartridg.
Harrie
Level 3:
Top Expert:
  • Toshiba Master 6,746 Answers
  • Posted on Mar 13, 2015
 Harrie
Toshiba Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283761
Points
83153
Check the contacts on the toner cartridge and in the printer are clean and shiny. They also must have no dent.
We on Fixya only try to answer questions via this page. We don't send mail.
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Nov 20, 2007
SOURCE: Toshiba e studio 150 problem
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
Anonymous
  • 86 Answers
  • Posted on Feb 19, 2008
SOURCE: Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Everett Lin
  • 990 Answers
  • Posted on Mar 08, 2009
SOURCE: We replaced the toner cartridge in our estudio232
Hello sir; that's toner motor defective , replace it! the parts no. is
41309035000
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 12, 2009
SOURCE: Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Anonymous
  • 2777 Answers
  • Posted on Sep 22, 2010
SOURCE: I have a Toshiba e
Wow that is a very strange issue, I don't know how the toner port could have rotated on it's own... Have you tried multiple toner cartridges in there and they all "leak"? It is fixable regardless, but it could be just a problem with that single toner...
Let me know what you find, or if you have tried multiple toners, and I can go from there. I am so sorry you are having this issue!
Tim
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
1helpful
How to replace toner cartidge of the Xerox Copier 5225 machine?
The toner cartridge is located in the upper centre of the front of the copier. Open the front door, slide out the cartridge until you see the top handle, whilst pulling out hold the top handle to avoid the cartridge tilting and leaking any excess toner inside the machine.
Before inserting your new cartridge, gently shake it from side to side to ensure even distribution of the toner. Slide the new cartridge in until you here a click, then close the front door. Your copier may go into a calibration routine for a minute or so if the developer has been starved of toner. If it hasn't, it will be ready to copy straight away.
For a quick user guide on the copier go to http://download.support.xerox.com/pub/docs/WC5225_WC5230/userdocs/any-os/en/EN_Online5230_5225_5222_QUG.pdf
Hope this helps.
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
2answers
New toner cartridge not working, Toshiba e-Studio232 Photocopier
Is the cart, a OEM or third party, Mite require only OEM, with the proper circuit board on board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
