Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Charging i cant get my nomad zen xtra to hold a charge or to come on anymore. should i buy a new battery or do i need to try and send it to the manufacturer.i stay in chicago so maybe someone can point me in the right direction.
Posted by 1kill on
  • czar_snchz Dec 08, 2008
    i can olny use my zen when its charging but when its off the charger it just cuts off how can i solve the problem?
Cary Farah
    President:
  • 4,402 Answers
Sounds like the usb port has loose connection.
Posted on Dec 08, 2007
Locked
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
Feb 01, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Nomad Creative Zen Xtra
You might have a bad "New" battery....after you have charged it can you take it out and use a multimeter to see if it has a charge? If its not taking a charge its one of two thing....either you "New" battery is bad or the Zen is bad and is not transferring power to charge the battery...if its the Zen then I would send it back under the warranty.....You can pick up an inexpensive multimeter at your local RadioShack to check both....Good Luck and let me know if this helped
cbinny1
Oct 18, 2008 | Creative Labs Zen V MP3 Player
My zen jukebox turns off then on and I just replaced and charged a new battery
Take out the battery. Plug it in. Does it play reliably?
Yes: That's a bad battery.
No: reset the device, and try above again.
Aug 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
New Battery Charge?
This means your unit does not see the battery and is running on AC power only. You need to check and make sure that your battery polarity is correct making sure that positive goes to positive, and negative to negative. If you can attach some photos, that might help also.
Aug 13, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Battery won't charge
http://www.anythingbutipod.com/forum/showthread.php?t=10960
If that doesn't fix it try the USB cable
Jan 16, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Zen Jukebox Xtra 60 GB
read this forum see if it helps you
http://www.anythingbutipod.com/forum/showthread.php?t=14486
Dec 28, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative nomad zen xtra 40 gb mp3 player won't power on
TDG1 do you get the same where the logo comes up? or is yours dead?
read this tread in the middle is the solution
http://forums.afterdawn.com/thread_view....
Nov 10, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
103 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
