Question about Sony Ericsson K800i Cellular Phone
1 model plz prise
Posted by 1 model on
Anonymous
    President:
  • 1,017 Answers
No problem.
Posted on Feb 25, 2008
Farmville taking away prises, and not letting things go thought
that is a farmville issue we don't adjudicate the farmville or facebook platform here at fixya
May 31, 2012 | Zynga FarmVille by Zynga
How do I open DUET - 2.0 COMPUTER SPEAKERS BLACK
You need to gently prise off the front speaker grill. You could use a blunt pen knife to do this. After you remove the grill You will see 4 additional screws at roughly each corner of the front panel. Unscrew them and then you can use the pen knife once more to prise apart the speaker housing. Prise the housing apart from the top because two base pads hold both halves together at the bottom. I hope this helps! :)
Feb 06, 2012 | JBL Duet Computer Speakers
*,#,o right cursor and down cursor r not working in my cell nokia-5130 i took it to the shop they sai that its ic need to be changed what shud i do???????
FIRST CHANGE YOUR KEYPAD BEALT ITS PRISE IN INDIA HALL SEL 120.00
THEN KEYPAD ICS PROUBLEM SO CHANGE KEYPAD IC ITS PRISE IS ONLY 20.00
BUT THE SHOP KEEPER SAYS ITS PRISE 200 TO 250
IDRISH 911
Oct 22, 2010 | Nokia 5310 Cellular Phone
Need instructions to replace hazard switch on VW Golf 2004 model.
its just a wedge/spring fit,just prise it off with a wide screwdiver.alt top and bottom...
Sep 25, 2010 | 2004 Volkswagen Golf
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
Monitor LCD 900P, open info please
Ok well at the rear edges of the unit there should be some way of opening it up... either screws or perhaps it even simply just "Clips" together.. remove all cables as can, then remove any screws in the rear outer edges.. &/or use a fine knife like flat instrument and work it in between the case halves and sorta wiggle gently.. this should prise 'em apart be gentlly forceful.. lol also try Googling for a Service Manual for your Model.. that would be of immense help. GL
Jul 29, 2008 | Fujitsu Siemens Business Line E18-1 18.1"...
Need anew screen for my Lap top....prise and how to oder
check ebay. You'll need to search based on your model laptop but typical prices are around $150
Jul 08, 2008 | HP Computers & Internet
Konka D163
where do i buy a display screen for a konka d163
Mar 25, 2008 | Cell Phones
Sony Ericsson K800i Cellular Phone Logo
16 people viewed this question
Top Sony Ericsson Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
