Toshiba Satellite M115-S1061 Notebook Logo
A
Anonymous Posted on Mar 12, 2015
Computer powers on but screen goes off unexplainably while power still on.
Terry Hair
Level 3:
  • Toshiba Master 4,134 Answers
  • Posted on Mar 12, 2015
Terry Hair
Toshiba Master
Level 3:
Answers
4134
Questions
Helped
1090309
Points
16804
Laptop computers have power saver features that will blank the screen after a period of no input. Default on these can be as short as one minute. Users can change these settings to avoid screen blanking, especially when doing thins like watching movies or streaming video. The power saver feature may be different, and thus the screen shut off timer may be different when the unit is plugged in.
Is there a fuse for the coil pack on a 2003 ford e 150 cargo van
none!
sign of bad coil pack.
power symptom = rough idle, unexplained and abnormal loud engine, and power lose.
drop of RPM during accelaration and engine ligth comes on.
abnormal stream of exhaust smoke.
2answers
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
Screen goes to power saving mode after
THere is problem in your video card ore check all cables carefully that they are connected
Tom tom xl does not turn on. been on charge all night and using car charger still makes no difference
try the usb cable to your. this is the recommended method to charge a tomtom when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
2answers
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
1helpful
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
1helpful
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
3answers
Unexplained Blank screen.
Looks like your Power Supply has gone Kaput .. Usually it is the Electrolytic Capacitors on the Power Supply Board, try a new one, or replace ALL the Electros with same or better ones.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
