SOURCE: unlock 1 GB micro sd memory card of Kingston Made
the same thing happend to me i reformated it but it dident open the best thing is to go to nokia
SOURCE: how do i put music on my motorola ve240?
Its seems that the format of songs that you are copying in your memory card in not supported by your mobile, your mobile only support MP3, AAC, AAC+, AMR, MIDI
it might be possible that your are copying MP4 files which will not run on your mobile....
So, please try to use the MP3, AAC, AAC+, AMR, MIDI files only
SOURCE: doesn't show mp3 files on micro sd card
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You will be really happy to know that you can add music to
your Kyocera X-TC cell phone. First you should
have already saved MP.3 music to your music file
in your computer. From what I understand the Kyocera X-TC will only play MP3
format.
Here's what I did.
First you'll need the following items:
1 Micro SD disk
1 adapter to hold the Micro SD disk
1 card reader - You insert the adapter into the Card Reader then connect the
reader to a USB port in your computer and download the music from your computer
to the Micro SD drive. I purchased a great 12-n-1 Iogear Card Reader from
Walmart.com for under $15.00
Steps to formatting the Micro SD and downloading music to the Micro SD disk:
First: Remove the battery from your Kyocera X-TC for 30 seconds
Second: Put the battery back into the phone and PUT THE MICRO SD DISK IN
THE PHONE and turn on the phone
Third: The phone will automatically recognize the Micro SD disc and
a message will appear "Your disc is not formatted. Would you like to
format this disc" and of you would of course choose "Yes".
Fourth: After the Micro SD disc is formatted, place the Micro SD into your Micro
Adapter, then place the micro adapter in your card reader and plug the reader
into the USB port in your computer.
Five: After you plug your card reader into the USB port your
computer will open up the Micro SD disc in a drive like drive I: and you'll find that that drive has two files
a Music file and a Picture file.
Six: Then you open up the file on YOUR COMPUTER WHERE YOU SAVED MUSIC in
MP3 FORMAT
Seven: Then right click and highlight on all the MP3 songs
you want to save to your Micro SD disc and choose COPY
Eight: Then return to the drive where your Micro SD disc is and PASTE THE SONGS
TO MUSIC FILE IN THE MICRO SD DISC, and that’s it. From here you just put the
Micro SD disc into your phone and watch the songs upload. Hope this helps!
SOURCE: I have forget password of micro sd memory card
You do not have a password to unlock you memory card. The things you should do is to look at you and if you can see a small button you just only slide it to unlock. After that you can use your memory card now.
