Question about Lands Phones
Tried to change to daylight saving time, but it keeps changing back to standard time.
Posted by Joyce Lochert on
  • Joyce Lochert
    Joyce Lochert Mar 12, 2015
    Yes, date is set correctly.
  • ziggy kois
    ziggy kois Sep 27, 2016
    Model is st2118
Steve
  • 3,289 Answers
Hi Joyce,
Your device *might* be pre-programed to adjust for ST to DST changes on another date. In 2006, the ST to DST change took place on the 1st Sunday in April and the DST to ST change took place on the last Sunday in October for the last time.
Congress decided that beginning in 2007, that the ST to DST change would take place on the second Sunday in March and DST / ST change back would take place on the first Sunday in October - and has ever since. So, you'll likely see the mismatched time again in November.
If it worked last year - then there is another issue. Unfortunately, without your brand and model, there's little anyone can do to help you out. If you need more help, reply and be sure to include the brand / model info of the device.
Clock changes in Washington DC District of Columbia in 2009
Posted on Mar 12, 2015
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Tried to change to daylight saving time but it keeps changing back to standard timee
change your location, that'll auto change time zones and the correct time
Mar 12, 2015 | Lands Phones
How do I change time and date on LG440G Tracfone?
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
Mar 09, 2015 | LG Cell Phones
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Daylight saving time problem
Sorry it took so long to reply to your questions about the change for the new daylight saving standard. The following link will take you to the customer support page for Emerson Radio. This page contains the directions for making the all the proper changes to you Clock/Radios. You will need a pdf reader and writer to read the information and make a copy for your records. [http://www.emersonradio.com/owners/SmartSet%20Series/DST%20Information.pdf] Copy this link and paste it into the address bar of your web browser. I hope this information helps you solve you problem with new daylight saving changes to your Clock/Radio. Thank you for using FixYa and have a nice day!
Mar 09, 2008 | Emerson Smartset Clock Radio
Model CKS2237 Daylight Savings needs to be reprogramed
Sorry it took so long to reply to you questions. The following web link will take you to the Emerson Customer Support web site for making the Changes for the New Daylight Saving standard. You will need a pdf reader and writer to read the web page and make a copy for your use. [http://www.emersonradio.com/owners/SmartSet%20Series/DST%20Information.pdf] Copy this web page link and paste it into the address bar of your web browser. If you are still having problems with making the setting for the new daylight saving standard you can call the Emerson customer support at this telephone number 1-800-909-1240. Call them between the hours of 8am and 4:30pm central time USA. Give them the make and model number of your Clock/Radio. Ask them for their assistance to help you make the correct settings for your Clock/Radio. I hope this information helps you, solve your problems with the setting of the Clock/Radio, to the new daylight savings standard. Thank you for using FixYa and have a nice day!
Nov 05, 2007 | Emerson Smartset Clock Radio
Clock changing
No, the owner's manual does not mention daylight savings time.
If you lost yours, you can download it here:
http://www.geappliances.com/service_and_support/literature/
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Lands Phones Logo
143 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
