Question about Samsung WF203ANW Front Load Washer
Washing machine is leaking from the bottom
Water is covering my floor and is not coming from the connections or door. any help?
Posted by texasfortune on
  • Anonymous Mar 02, 2008
    I Have Fully Automatic Samsung washing Machine and its Digital panel having an IC No SW-5C2. HD404358A14S 3A1 JAPAN PLS HELP ME FROM WHERE I CAN FIND THE SAME SO AS TO MAKE MY MACHINE WORKABLE AGAIN
  • Anonymous May 09, 2009
    Exact same problem in the same spot... boo-ures!
sanjeev arora
    New Friend:
Want to washing machine cover where i buy for dust
Posted on Oct 10, 2011
Anonymous
Samsung toploader automatic is not working the water drainage. any one can hel?
Posted on Mar 06, 2009
Anonymous
I had a hose blow inside the machine 3 times.
Posted on Jun 17, 2008
Anonymous
Check under the front corner of the machine - I had the same problem with mine, which was damaged during delivery. Mine had a part broken on the water pump - where the emergency drain hose attaches to the water pump the little plastic connector had broken off.
Posted on May 31, 2008
Anonymous
Try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Posted on Dec 29, 2007
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Washing machine comes up flashing with a de sign
LG machines with DE (Drain Error) Water has not drained enough in 5minutes...Probably due to a partially blocked pump filter....Repeat drain to empty machine and cleat pump filter,,,Access via small door at floor level, unscrew pump cover, and clear filter... Some water may be released. Leaning machine back can help!...Good luck..Nomess
May 17, 2010 | Washing Machines
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
Water leaking on the floor from fridge
That might be a leaky water valve connection Or it could be bad door gaskets.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 15, 2010 | Refrigerators
How do I remove the doors?
Refrigerator side is easy. Remove the top hinge cover and then the hinge. Lift it off the bottom hinge and set it to the side. The freezer side is a little more entailed as it has a water and electric connection. Remove the lower kickplate (Grille) and then you will see a plastic tube coming out the bottom of the hinge. Follow it to the connector and removed it. A little water might come out but it will stop. Next, go to the top hinge and remove the hinge cover. Unplug the electric connection and then remove the top hinge. Lift the door off the bottom hinge sliding the plastic tubing through the hinge...This should do it. If you need further asssistance, we are here.
Eric Campion
Feb 21, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water leak at door but seems to come from door itself.
no seal in outer door, but that's what you need outer door frame about 300.00 , labor 152.00 buy service smart agreement from sears it will cover parts put to 500.00 it will fix it "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wet Floor
sounds like a heater core
Oct 01, 2008 | 2002 Toyota Tacoma
I moved, and now the water no longer comes out the door
The electrical connector at the top of the hinge cover is not connected properly.  Pull the left hinge cover and make sure that the electrical connections are secure.
Jun 19, 2007 | LG LRFD21855 Stainless Steel French Door...
Samsung WF203ANW Front Load Washer Logo
1,586 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
