SOURCE: what is an error code e00001-0010 on a canon
I think there are
The main motor is faulty.
The clock pulses do not arrive for 2 secs or more after the main
motor drive signal has been generated.
SOURCE: Our Canon Image Runner is showing the error
You have a problem with our fuser assembly - located where you pull out the left printer door - it is the very hot assembly where the paper leaves the machine - it will either have a yellow or black felt cover. Only two screws hold this unit in - one at the back and one in the font. Take this unit out and look for trapped paper in the rollers that could also cause the fuser temperature readings to be incorrect. If you cannot find any paper, reset the code in service mode and turn the machine off/on. If the problem returns as you power on - you will need a new fuser unit. To clear the fuser error enter service mode as follows:
Press the head key (head shape with star inside) - 2 and 8 at the exact same time - then HEAD key again. You should now be in service mode. Now - COPIER - FUNCTON - CLEAR - ERR - OK. Then turn off the power and on again - this may cure your problem indefinetly or definetly. But even if you find paper in the fuser, you mUST perform the CLEAR procedure or the error code will not go away. Good luck.
SOURCE: give me the solution for my canon image runner 2520 photocopier which shows error code e000002?
Well try this method unplug for 30 second and plug it back push start and off button at the same time and hold it for 10 second and let it go then try to text copy and see if it work
Good luck
