Question about Excalibur Televison & Video
Put new battery in my Excalibur remote,now it doesn't work and the keypad stays lit
Posted by Robert Hemingway Jr on
richie46
    Top Expert:
  • Excalibur Master
  • 12,962 Answers
Let it sit for a day without the battery. Push all of the buttons on remote while battery less to discharge any and all caps.
If it still does not work with new batteries then the RC has gone to remote heaven and needs to be replaced as I had to do.
Posted on Mar 12, 2015
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I code the garage door wireless key pad?
simple ;find the smart button on the opener and pressit ,their will be an indicater light next to the smart button that will remain lit ,then go over to the keypad and put your 4 digit code in example1234 then press enter on keypad and hold down for 3 seconds until garage door opener lightbulbs shut down and come back on , and thats it simple as pie! when the lights go on and off on your machine it,s telling you that it has received the code that you just programmed into it , guaranteed to work everytime , Thank you for letting me help you Sincerely Glenn mayer
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
Change code on keyless entry. Now the remote does not work.
Did you clear the codes existing in the unit? (Press and hold the learn button; LED light will stay lit for approx. 6 seconds.) If you have remotes that have dipswitches, pop the battery cover off and make certain that all switches are set identically in each remote. Now, press the learn button on the main unit and immediately release. While its LED light is lit, press the button on ONE of the remotes only. They will ALL be programmed at this point. Now, press the learn button once more (quickly and release) and enter your number code on your keypad and press enter. It should be programmed now, too.
I was having a similiar problem, and this turned out to be the solution. Before, I was programming both remotes, not knowing as I did so that by programming one, and then another, I was UNprogramming the the first as well as the keypad.
I hope this works for you. It did for me.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
81 people viewed this question
Top Excalibur Televison & Video Experts
Marvin
Marvin
Are you an Excalibur Televison and Video Expert? Answer questions, earn points and help others
