Question about Air Tools & Compressors
How do i rewire a broomwade 3 phase compressor 1970
J Rosado
  • 1,164 Answers
Rewire for ?? High voltage motor wiring is L1-T1, L2-T2, L3-T3, T4-T7, T5-T8, T6-T9. Low voltage is L1-T1-T4, L2-T2-T5, L3-T3-T6. The motor protection overloads will need to be sized accordingly, to the motor's FLA ( full load amps) for the voltage used. The control needs to be looked at also, if there is a control transformer, the transformer needs to be wired or repaced for the new supply power voltage used.
Posted on Mar 12, 2015
Need wiring diagram for a single phase brook motor n a broomwade compressor
I suggest you contact Brooks if they are still in business. If not there is lots of motor info on the net.
Traditional single phase motors are fairly straightforward and similar to each other. The main thing to watch out for is to have the start and run windings wired with the same polarity. If the polarity is reversed on either winding the motor will run backwards.
Feb 06, 2016 | Air Tools & Compressors
How to rewire a broomwade 3 phase compressor 1970
Look for a stardelta wiring diagram and you need to fit a thermal cutout and also a pressure switch
Mar 12, 2015 | Air Tools & Compressors
Wire diagram to change a royal sun tan bed model # 46/6 vhr*turbo 1100 from 1 phase to 3 phase
send me your email address and I will give you what I have. We have a 2004 model 46/6 turbo. Wiring diagram is in the manual. I have this.
Jul 26, 2012 | Cars & Trucks
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
Ac compressor motor is wired for three phase need to rewire for single phase
Most cannot be rewired... but some can... before I can help I do need to know the make and model though...
heatman101
Apr 27, 2011 | Garden
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
How do you rewire a 3phase hobart convection oven into a single phase
Here is your answer :
From 3 phase con you took just one phase of this 3 phases and a blue vire and earth wire you should use allso! for the safety against electrick shock,
I hope this will help you
Sep 23, 2010 | Ovens
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Can i convert a 3 phase 10hp qrs compressor to single phase?
Search the 'net for phase converters. I have read articles about making your own phase converters from old 3 phase motors----Fine Woodworking mag.
Apr 26, 2009 | Chicago Pneumatic Qrs 5 HP/3 Phase Rotary...
Can a lang griddle wired for 3 phase by rewired to run 1 phase?
Yes, there is a chart on page 6 of the service manual that tells you which wires to switch(according to your model#) to change to single phase.
Jan 03, 2009 | Lang Manufacturing Kitchen Appliances -...
Air Tools & Compressors Logo
112 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
