Question about Dell Computers & Internet
Sims 3 i have a dell dimensuon 3100 & i was wondering how could i get sims 3 to run and how much does it cost Any help? :D
Posted by funkygirl_ka on
Lee Hodgson
  • Dell Master
  • 4,810 Answers
These are the system requirements for Sims 3 PC version>>>>>>>
Windows XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB video card with support for Pixel Shader 2.0
Windows Vista
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least
  • Intel Integrated Chipset, GMA X3000 or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
You can download a demo version from EA Games here before you buy it >>>>>>>>
http://eastore.ea.com/store/eaemea/en_GB/ContentTheme/pbPage.sims3uk
Regards.
Posted on Jul 09, 2009
Dowfree download sims 2
You must post your system specs in order for anyone to answer that question.
Sims3 is incompatible
I assume you running it on Windows 7 32-Bit. Now before you trying the tips below, do make sure your computer is compatible and meet the Sims 3 requirement.
The Sims 3 can be run on a PC with Windows XP and Vista, and on a Mac. However, there is no official Windows 7-compatible version. This means that Sims 3 will not install on Windows 7 properly.
To fix this error, you need to run Sims 3 in Compatibility Mode. To do that, simply right-click the Sims 3 icon, select Properties and then select Compatibility. Then check the Run this program in compatibility mode for box and select Windows Vista or Windows XP SP3. The game should work fine.
Sims 3 has stopped working
Hi, What OS are you running? win 7 , XP? If win 7 right and give admin rights.
I had a similar problem but seems that Sims 3 needs a good graphics card. I was using my onboard graphics. I put in a graphics card that I had, 1 gig Geforce 9800. Now sims 3 is working great. I hope this helps
2answers
How can I change The Sims 3 Region Code?
Wondering if you need to change your ip address .
to denmark during the installation process ?
https://www.how-to-hide-ip.net/browse-danish-ip-address/
Not sure if it would help ?
Does it need to access the internet to install the expansion ?
I have a dell desktop computer and it wont play dvds or run the sims 3. i have a video card so i dont think it has to do with that
please try to describe at which step do the problems occur. You have inserted the sims 3 dvd and then there should come some SIMS start screen. If not, you can navigate to your dvd on your computer by clicking on START > My Computer > "Sims.."
Of course it wont have to do with your graphics card. First you have to install the game according to the instructions on the screen and then you will be able to play it. Try to initiated the first few steps mentioned above and reply..
1helpful
Dell Inspirion mini 10v XP gets graphic error (Directx 9.0C) then running Sims 2.
The graphics chipset in a Dell mini is not capable of running Sims 2. It requires far more power than you are going to get from a Netbook. Even some standard Laptops would be hard pressed to run Sims 2.
Netbooks are for email and web browsing, and that is about it. You'd be lucky to run even a simple Flash-based game on a netbook. Sorry...
JUST BOUGHT SIMS 3 AND TRIED TO INSTALL IT i HAVE THE REQUIREMENTS FOR THE GAME TO RUN. iT WILL INSTALL IN A HP COMPUTER, HAVE 2 OF THEM AND i ALSO HAVE 3 DELL COMPUTERS BUT IT WILL NOT LOAD IN THE DELL...
This is most likely because Sims 3 comes on a DVD, not a CD and your dell computers only have CD drives in them and not DVD drives so they cannot read the Sims DVD.
The sims 2
Fix Ya does not support Cracks And Hacks if you are missing your cd key or serial try contacting the software provider but i can tell ya most will not do anything for ya
Google Might But Not Here
2helpful
Sims 3 graphic card compatability
Yes The SIms 3 can be run with this Video card
Dave
Computers & Internet Logo
Ekse
Mandeep  Singh
Mandeep Singh
Mehandi Husain ...
