Screen goes black but sound is good.
Screen goes black after a couple of seconds. The sound is fine. The screen can be illuminated, momentarily, by pressing the display button on the remote control. The picture can be seen by shining a torch onto the black screen.
Posted by Peter Cogley on
Chris Neary
    Master:
  • 369 Answers
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Posted on Mar 12, 2015
  • Peter Cogley
    Peter Cogley Mar 12, 2015
    Thanks for the advice. Unfortunately i have already tried changing the inverter, AV and PSU boards without success. I think it has something to do with the display switch but I don't know where it is?
  • Chris Neary
    Chris Neary Mar 12, 2015
    plasma TV ? EHT safety shutdown maybe?
How do i reset the projection lamp timer?
Hello
Press the "Power" button on the TV remote to turn the TV on. Press the "Display" key. Press "5," followed by the "Vol+" key, followed by the "Power" button. Wait for the service menu screen to appear on the screen. This could take anywhere from a couple of seconds up to a minute or two.
Press the "Jump" key three times in rapid succession. Press "2" nine times in rapid succession
Press "3" once, followed by the "Mute" key, followed by the "Enter" key. Wait as the screen flashes momentarily.
Press the "Power" button on the TV to exit the "Service menu" and turn the TV off.
Mar 15, 2011 | Televison & Video
Every time I turn it on, it displays nothing, just a black screen.But the power indicator is on and there are some white lights flashing next on the Caps lock button and above the scroll button..
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Computers & Internet
I need to reset the b service on my clk550. How
1.- Insert key into ignition, switch to position "1"
2.- Press the menu buttons repeatly until the mileage is displayed within the multifunction display.
3.- Press the cluster illumination button (trip reset button) 3 times in short succession. The battery voltage will be displayed and an audible signal will sound.
4.- Turn key in ignition to position "2"
5.- Press the Up and Down Arrow buttons until service menu appears.
6.- Press cluster illumination button (trip reset button) once. The oil type menu is displayed.
7.- Use the + and - buttons to select the oil used for service.
8.- Press the Up and Down buttons to confirm. The display will show : "Reset Oil Confirmation. Push Illumination button for 3 seconds".
9.- Press and hold the cluster illimination button for 3 seconds. The message "Service confirmed" is displayed.
Mar 01, 2010 | 2007 Mercedes-Benz CLK550 Convertible
Pioneer AVH-P4000DVD video goes black after 2 or 3 seconds. I can touch screen and it comes back but for only a couple of seconds. Audio is fine
You pressed the Disp. Off button on the bottom left corner. If you press it again it will stop turning the display off.
Oct 25, 2009 | Pioneer AVH-P4000DVD Monitor
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Televison & Video Logo
486 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
