Question about Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV
Shoud light red light flash behind charge indicater when switched on on hurricane
When key is inserted light flshes behind the charge indicater on tiller
Posted by frederick cotsford on
  • frederick cotsford
    frederick cotsford Mar 14, 2015
    thanks for reply the light comes on when key is turned it flashes contihualy behind the charge status on tiller
Rob Hill
  • Pride Master
  • 1,414 Answers
Hi, is this still a issue, this is a fault ....
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 13, 2015
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
Standby light flshes 7 times on tv sony KDL-46z4500
that is power supply issue try to check if there is bulged capacitors on power board then replace it.
Oct 28, 2012 | Televison & Video
Keeway hurricane 50 .the electricty went off suddenly
Hello and happy thanksgiving from the USA.
I would suspect that you have a defective igntion switch, the igntion switch is what powers up all of the electrical system when you turn the key to run, the contacts can get burnt or the connector or both. The switch is under/behind the ignition key cylinder which operates the switch or course.
Nov 24, 2011 | 2008 Keeway Hurricane 50
Tv wont turn on, red timer/delay light flashes starts to come on then shuts off again
hi,
watch how many times ur standby indicator flashes. flashing of led is its self diagnosing system. if u tell me how many times its flashes, then i can tell u where is the problem
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V ([email protected])
Apr 15, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Braun Syncro 7680
the red light tells you it is cleaning, a green flashing light tells you it's charging
Jul 28, 2008 | Braun Syncro 7680 Electric Shaver
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
The phone will not turn on the infared light flshes when I try o turn it on
if the battery is already charged., remove it from your k800i for couple of hours about 3 hrs. then put it bak in the phone., press on button., if this doesn't work flash your phone with the latest software(go to the SE site., the update service is under the supprt tab) if the fone's battery is already drain then fully charge it., then remove the battery and wait for 3hrs
Aug 18, 2007 | Sony Ericsson K800i Cellular Phone
Pride Hurricane 4 Wheel Personal Mobility Vehicle PMV  Logo
94 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
