Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing new string line for Ryobi 4 cycle straight shaft s430
I lost the manual for my Roybi 4 cycle straight shaft trimmer.
Never changed the line on this model before. Need help.
Thanks.
Mike McDowell
Level 2:
  • Expert 148 Answers
  • Posted on Jul 14, 2009
Mike McDowell
Expert
Level 2:
Answers
148
Questions
0
Helped
90285
Points
359
Go to www.managemyhome.com and download a free copy of the onwers manual.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3694
Points
There is no such manual for this at the site you've specified.
2answers
Ryobi install new line s 430
https://www.youtube.com/watch?v=5Y5em-UtokQ
If you find this useful please click the 'helpful' tab. thank you
What size fuel line for Ryobi Homelite Fuel Tank Fits Trimmers 308181008
Ryobi makes a neet little fuel line kit for these , and its inexpensive too , it contains a new fuel filter (and tool for installing it) a new primer bulb (change it anyway) and enough of two different fuel line to reach your trimmer's carb , I stock a few of these here and you can buy ne from any roybi dealer , the only tool you need besides your fingers are a pair of scissors and a Phillips screwdriver for taking off the air cleaner to gain access to lines
directions are included on back of package
Automatic line advance not advancing on Ryobi 18v trimmer
I have a Ryobi Model RY28040 straight shaft line trimmer. In my case I replaced the complete String Head Assembly that includes the String Head Housing, Spring, and Spool and the string still did not advance. I then discovered that the bolt in the Spool Retainer cap (the red cap that attaches the spool to the shaft) was fused and not moving. The bolt needs to be loose inside the cap in order to allow the spool to move in and out by the spring. I loosened the bolt and fastened the spool back onto the shaft. Fired it up and bumped it a few times and the line began to advance. Turns out I probably only needed to replace the Spool Retainer rather than the String Head Assembly.
1helpful
2answers
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
7helpful
2answers
Does a Ryobi trimmer S430 not use a fuel mixture?
the Ryobi S430 is a 4 cycle engine. As such it has an oil reservoir which takes 30 weight oil. It uses straight gasoline in the gas tank.
Ryobi CS30 straight shaft. I can not get the string head off to replace the line.
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
5helpful
5helpful
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
