When i want make photo, to appear me this message:,,this card cannont be using''
I inserted the card into the machine, I opened it to take pictures, but appears message: this card cannot be using,,,and does not let me take pictures.
to mention: i do not walked at card and before happend me this, i made pictures.
Testimonial: "hello Clive Gray ! i use the same card with which i had done pictures. I took pictures with the same card. With the data cable, we transferred the photos on computer. I wiped the few photo on computer, photos come from camera Nikon Coolpix 5 700. After, I wanted to do other pictures with the camera but, appeared to me : ,,this card cannont be using''."
if you erased the photos from the card using the computer, you may need to format the card again. I use CF cards in a video camera and if I delete items using the computer that's what I have to do.if you erased the photos from the card using the computer, you may need to format the card again. I use CF cards in a video camera and if I delete items using the computer that's what I have to do.
You can't post conmments that contain an email address.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.After copying your photos to the computer, then you can delete the photos from the memory card using your computer.
you can recover pictures from sd card with SD Card Recovery Software like asoftech photo recovery, the card recovery software not only recover photos, but also videos, music files and other files. download the software from SD Card Recovery Software
Pretty cool that the newer computers are coming with an SD card slot. However the computer looks at this as an external hard drive and I don't think the pictures are just going to automatically pop up on the screen. You will need to go find the "drive" click on the folder and open, once you have the pictures open you can select all copy and then create a folder on your computer hard drive and paste the pictures in that. Once the pictures have transferred do a safe eject of the SD "drive" and remove the SD card. Don't forget to do a format to the card once back into the camera.
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on. Insert a memory card. • Insert the card with the brand name label facing up. • If there is an arrow on the card, make sure it points toward the printer. • If needed, make sure you connect the memory card to the adapter that came with it before inserting it into the slot. Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory card is being read or is transmitting data. • The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears on the display prompting you to remove all memory cards inserted. • If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you to choose which memory device to use. When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer. xD-Picture Card • Secure Digital (SD) • Secure Digital High Capacity (SDHC) • Mini Secure Digital (with adapter) • Micro Secure Digital (with adapter) • MultiMedia Card (MMC) • Reduced Size MultiMedia Card (with adapter) • MultiMedia Card mobile (with adapter) • Memory Stick (MS) • Memory Stick PRO • Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
To transfer pictures:
1. Remove the memory card from the camera.
2. Insert the memory card into the floppy disk adapter.
Make sure that you insert the memory card into the adapter with the gold side of the memory card facing you and to the right and the silver side of the adapter facing away from you.
3. Insert the floppy disk adapter into the diskette drive on your computer.
4. Double-click the PhotoMAX shortcut on your desktop to open the software.
5. Click Get Photo.
6. Click Album or FlashPath.
7. Click Downlod from FlashPath. The images appear as thumbnails on the album manager window.
8. Double-click the image that you want to edit. The image appears in the image tray.
9. Remove the FlashPath Floppy Disk Adapter from the diskette drive when you are done.
