Motorcycles Logo
Alex rainford Posted on Mar 11, 2015
Is it a big job to change your gear leaver spline. On a ktm 250 sxf
Paul Hoehn
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Sep 26, 2015
Paul Hoehn
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
5189
Points
21
Its not to bad .You will need to purchase a shift shaft a shift shaft seal and a primary cover gasket and oil.First drain your oil.Remove your kick starter .Remove your primary cover.Remove entire clutch assembly.You will need air gun or a clutch holding tool to remove the clutch.Once you have the clutch assembly removed yuo can remove the shift shaft .Pay attention to the postion of the shift shaft in relation to the shift drum .Also pay attention to any shims on the shift shaft as that will need to be installed on the new one.Now remove the seal that the shaft was coming out of.Replace the seal install the new shift shaft.Make sure to center it in relation to the shift drum.clean every thing with brake cleaner.clean gasket area .Install the clutch assembly .If you have any trouble with the oriantation of the parts you can look at world of power sports for parts diagrams.Make sure you tighten the clutch hub to the proper torque spec.I would use blue loc tight on the nut as well .If you have a shop do it expect to pay about 2 hours labor max.Plus parts
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 17, 2009
SOURCE: 2007 ktm 450 sxf timing
i could tell ya easly or u could just go to dirtrider or transworldmx websites and they'll give u detailed pics so itl be easy
Anonymous
  • 1512 Answers
  • Posted on Apr 02, 2009
SOURCE: head bolt torque
Hi bengriffith1
You can download a copy of the engine manual from here
It has all the info you need. Any problems with the download just let me know
regards robotek
Anonymous
  • 14 Answers
  • Posted on May 20, 2009
SOURCE: ktm 250 sxf 2008 backfires
go on google check the air mixture and altar the air screw on the carb to wot u find on the net easy job thers only 2 screws on the carb
Anonymous
  • Posted on May 23, 2009
SOURCE: how much oil do you put in a 2006 ktm 250 sxf with
You can download an owner's manual for free here
http://www.ktm.co.uk/250-SX-F.28.19.html?&detailview=4&cHash=dcbf8829e1
tombones
  • 3567 Answers
  • Posted on Oct 27, 2009
SOURCE: i have an 08 ktm sxf 450 and we replaced all the
KTM is not my specialty but every bike I have ever worked on fits to the crankshaft by indexing on a pin or woodruff key. If there is a drill hole or a half mood divot on the crankshaft and the flywheel is loose when mounted, you don't have the pin or woodruff key installed.
Will not shift into first gear
Sounds like your clutch is out of adjustment, or needs to be bled. Most of the ktm's use a Magura hydraulic clutch which can be bled using Mineral Oil. DO NOT USE BRAKE FLUID.
2011 ktm250 sxf wont start
i have a 2009 ktm 450 sxf and was riding yesterday and it stalled out when i switched to fourth gear and wont start back. battery is good and when i hit the e start it just clicks once, and it wont roll start either. any suggestions? could it be the switch under the tank? PLEASE HELP!
Gear selector shaft replacement
take off gear selector remove kickstart drain oil cooling system take back brake pedal off undo outer casing remove casing take clutch n hub out remove shaft an reverse procedre hope this helps u
3answers
Have a 2006 ktm 250 sxf seized rod to the crank got it changed reinstalled put motor back together now can not even kick it like somthing is stuck. Toke the clutch basket out, timing gear and water pump...
Your clutch basket is the link between the engine and transmission. Your kick starter rotates the clutch basket gear, which turns another gear at the engine crank. Remove either the basket or gear at the crank and see if the engine, and the transmission both turn. Sounds like the engine is stuck for some reason. At least you can cut the issue in half.
2011 KTM 250 SXF valve clearance
.010" inlet hot .012" exhaust hot if water cooled
if air cooled add .002" to the measurements
Hi ive jst bought a 2007 ktm 250 sxf an im not sure how much oil i have to put in it wen i change it?
Most MX bikes take about 1 liter to 1100mm if you dumping the oil filter as well but ring your local KTM dealer to confirm
What Spark Plug Tool Will Remove My Plug From My KTM 250 SXF 2008? Spark Plug Wrench 16mm 1/2 Inch 60029073000 Spark Plug Key 77029072000 Didnt Get One With My Bike And Want To Order The Right One....
Motion Pro offers a tool that is half the price of the one KTM offers, that will do the job. I got mine at Bikebandit.com after searching all over for months trying to find a cheap alternative to removing the spark plug from my 2007 KTM 250 SXF.
1helpful
What type of gear oil should i be using in my 2007 250 sxf?
Owner's manual should have the recommended oil.
If you are missing one, try calling your dealer, or go online.
2helpful
Ktm 250 sxf 2008 backfires
Top KTM Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Are you a KTM Expert? Answer questions, earn points and help others
