If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name only to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: i have konka crt tv ,model number is
how about the amplifier ic does it work, check the supply voltage. then if you know the pin configuration of the ic, look for the input of the ic then bypass the amplifying section. the audio input connect to the connection going to the speaker out. if you can hear a sound from the speaker that was mean the ic is defective.
How to change language of my konka crt tv model no K2039D3 from Chinese to english
