M
Mike Upton Posted on Mar 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Marantz turntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I assemble them into a stack system please ? Thank you
I wish to assemble them into a stack system.
Harrie
Level 3:
Top Expert:
  • Marantz Master 6,746 Answers
  • Posted on Apr 16, 2015
 Harrie
Marantz Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283766
Points
83153
All the sources, turntable, CD player and tape unit have an output. These should go in the input of the amplifier with the same name. Then only the Tape player, could have an input, for recording music or whatever. For that input, your amplifier should have an tape out. All these should be connected with cables with tulip plugs, like these.
I have a Marantz turntable, a Marantz CD player, a - 25552376-zafysfg4poivsbrsahnsodzf-2-0.png
Use the white for left on everything and red for right.
If one of the devices as a different connector, find a cable for audio, with on one end the tulip plugs and on the other end the fitting plug.
Then the output of the power amplifier it should say output or LS, can be connected with 2 wires going to the speakers.
For this the same counts, although it is difficult to see when you use electrical wires in one colour. What comes out red on he amp, should go on the same screw connector on the speaker. Just to avoid one speaker being out of phase. It will work, but could sound a little strange when the speakers are out of phase.
With the correct model names added, perhaps we could have given a more accurate answer.
Success.
Please don't test the system or switch on, with the volume button to the max. Don't switch anything on an amplifier when the volume is high, or the setting is high. A short increase of the volume, during switching can, and has very often destroy(ed) the speakers.
Mike P
Level 1:
New Friend:
  • Contributor 32 Answers
Mike P
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
11034
Points
65
If it's truly an amplifier, and not a receiver, you will need a pre-amp to switch sources and control everything. Go to the Marantz USA site and download the manual for the model number you have. The manual will probably answer most of your questions.
Penzance Computers
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,003 Answers
  • Posted on Mar 11, 2015
Penzance Computers
Master
Level 3:
Renaissance:
Answers
2003
Questions
0
Helped
337384
Points
7859
This is not a stack system, it's a decent hi-fi setup.
Testimonial: "thank you for saying its a decent hifi setup, perhaps I asked the wrong question. how do I wire them up to work please"
  • Penzance Computers Mar 11, 2015
    Other than saying connect the turntable to the turntable input etc., it's difficult. Have you nobody you could ask to drop in and have a cup of coffee and help?
1helpful
Volume fluctuations
Does the volume fluctuate through speakers?
1helpful
I have a Marantz turtntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I wire them up please.
If you have a pure amplifier, there may only be one set of inputs, and one or two pairs of speaker outputs. The inputs are probably RCA plugs. Connect the CD or tape player to these. The speaker outputs are typically heavier binding posts or wire clamps. Each speaker should have one pair of wires. One for the 'Red' post, another for the 'Black' post.
If you have a 'Receiver' you will have several inputs to use and switches in front to select them. The CD and tape can be plugged into either tape, CD, or Aux inputs. (Not 'Phono') The speakers hookup is the same as for the amplifier.
You may also want to google the make-model of your amp to find a manual....
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
I am trying to connect my Eltax woofer to my Marantz M-CR502 CD Receiver. Have connected the single line "sub w out" socket on the Marantz to the "line input" on the Eltax unit but...
Sounds like this is a powered subwoofer (as it has a line input). If this is the case, the 'sub W' output of the receiver will NOT work, as it is only sending speaker level to the line input.
You will likely go from sub W directly into the speaker input on the sub. The output is probably used for looping an additional sub into the system.
1helpful
2answers
Just wondered if i can connect my speakers straight to cd player or do i need to go through an amp Thanks
Component CD players like yours must be used with an amplifier. Their output is called "line level" and isn't beefy enough to drive speakers directly. An amplifier is needed to boost those line level signals to speaker level. The same is true for other components like tape decks, DVD players and so on. A CD player may have a headphone output jack, though, since headphones don't require the same power levels as speakers. So you could use the player by itself for headphone listening.
Hope this has cleared the air for you. Thanks for using Fixya!
Hello, I am trying to plug my Mixer into my amp but only one speaker has sound..I am using a Rane ttm57sl mixer with technics turntables & cambridge audio azur 640a amp...I've gone from the Aux out on...
Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
2answers
CAN YOU PLEASE TELL ME HOW TO CONNECT A SET OF SPEAKERS TO THE CD PLAYER PLEASE? WOULD I HAVE TO USE AN AMPLIFIER THEN TO SPEAKERS AND HOW WOULD I COME FROM THE MARANTZ CD PLAYER ? THANKS -GRAHAM
You will have to use an amplifier to power the speakers from the cd player, the output on the CD player isn't enough. You will need to hook the CD player to the amplifier using the red and white wires, on the CD hook them to the OUT and on the amp hook them to the CD or Aux or Tape in. Then select that input on the amp and enjoy the music.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
1helpful
2answers
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
We have a Marantz PM493 amplifier with turntable, Tape, CD and radio decks connected. Dropped something on the ribbon cables, now all we get is feedback sound from stack system.Could it be that the ribbon...
Hiya Sally_fisher,
Is the feedback sound a low hum and also does this 'feedback sound" occur whether it is selected to CD, turntable, or on all of them regardless of select?
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
