Question about Microwave Ovens
Part number for turntable glass tray - Microwave Ovens
Posted by venkatraman on
Phillip Hicks
  • 917 Answers
Only two Sizes of Turntable Glass Tray , Each manufactuer has his own number, but any Microwave repairer / supplier can help you. Try Yellow pages.
Posted on Mar 11, 2015
What size turntable plate is needed for ge microwave jes738wj02
The GE JES738WJ02 uses the WB49X10134 turntable tray. According to Amazon, the tray measures ~9 5/8" in diameter. Sears Parts Direct has the parts diagram here: https://www.searspartsdirect.com/model-number/jes738wj02/0432/0123245.html . Amazon describes the tray on the part site: https://www.amazon.com/GE-Microwave-Glass-Turntable-WB49X10134/dp/B00DZPVBVY .
I hope this helps.
Jul 15, 2018 | GE Microwave Ovens
JennAir JMC7000ADW Microwave Oven Turntable not turning
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
The glass turntable has for my DAEWOO KOR-1B4H has never properly fit on the turning gear and continually falls off the track. Was this a common problem with the model, or did somebody just put the wrong ...
Hi and welcome to FixYa I am Kelly. You either have the wrong glass tray or one of the wheels on the lower caster / spinner is stuck. I think you have the wrong tray. Daewoo uses several different sizes of glass trays. See this link for examples: (and they are too small!)
http://microwaveglasstrays.com/shop/-c-21_73.html
Note the 10" (254 mm) / 11 3/4" (279 mm) / 12 3/4" (323 mm) sizes and the difference of the caster guides on the bottom of the plates.
I have been trying since 1 minute after you posted just to cross the KOR-1B4H number to a parts reference without success.
I did find one reference here: The price of the tray is outrageous!
http://www.expertappliance.com/partfinder.php
Part number is: Z11-KOR-1B4H -221 $94.33
Honestly I would probably use the email link on the page and ask what the size was of the tray and then SHOP SOME WHERE ELSE!
The interior dimensions of your microwave are:
Interior Dimensions: 14-1/2 in. W x 9-7/10 in. H x 15-1/2 in. D
I searched ebay and came up with this link: http://shop.ebay.com/sis.html?_kw=Daewoo+KOR1NOA+Carousel+Microwave+Turntable+Tray-Glass I think your turn table will be the 2nd one on the list. 14 1/4" That only leaves 1/8" clearance on each side of your unit. The last 2 on the page may be a better match at 13.5 inches leaving 1/2 in. clearance on each side of the turntable.
You can try and email them here and ask what is the replacement part number for the glass turntable: (also ask for a source!) [email protected]
I understand now why you asked FixYa for help. This one was a real challenge.
Thanks for choosing FixYa,
Kelly
Feb 25, 2011 | Daewoo KOR-1B4H Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Microwave
Shalene Naig
[email protected]
2873 410 Avenue
Graettinger, IA 51342
7128593720
I'd love to buy your glass turntable/
May 11, 2008 | Emerson MW8168B Microwave Oven
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
Marvin
Marvin
acmservice
Are you a Microwave Oven Expert? Answer questions, earn points and help others
