TV displays a small M and the word INITIALIZED. Menu -> Setup-> Reset does nothing. Inputs 1 and 2 are disabled. How do i enter service mode?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Type in the brand name only to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Contact Sharp to see if it can be a "reset" issue and to see if this is a known problem in this model----more likely than reset would be a possible software upgrade but it depends on what actual issue is---maybe a bad board somewhere in the set.
In order to enter Service
Mode, TV guide must be turned off
In order to do this
procedure you must have and use the correct remote. The full function
remote that
came with the set has a TV
Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not
yet been setup, then the 1st step is to follow instructions to set TV
guide up.
Enter ZIP code, cable or
ant. Etc.
1.press and release the
"TV Guide". TV guide will appear on the screen.
2.Navigate to the TV
Guide tool bar and use the ">" button to select "setup"
in the menu and press
and release the
"enter" button
3.use the "arrow
down" button to select "default options"
4.press and release the
"enter" button and select "general defaults"
5.press and release the
"enter" button (opens menu on lower left side)
6. use the "arrow
down" button to select "auto guide"
7. use the ">"
button to select "off"
8. use the "arrow
down" button to select "done"
9. press and release the
"enter"
10. press and release the
"TV Guide" button to turn the display off
System Reset
Using Service Mode:
1.
Enter Service Mode
2.
Use the "muting" button to select "initialize"
screen
3.
While on the "initialize" screen
4.
Use the "down arrow" button to select "final setup"
5.
Press and release the "enter" button to select "data reset"
6.
Use the ">" button on the remote to select "yes"
7.
Press and hold the "enter" button until the screen goes
black release "enter" button on remote.
8.
Power the unit off using the remote control
9.
Unplug the power cord from the media receiver to complete the reset
10.
Plug in the media receiver; turn the system on and reset is complete.
ok
