GMC 2003 Envoy XL Logo
tony rodriguez Posted on Mar 11, 2015
MY 2003 GMC ENVOY XL SAYS BATTERY ISN'T CHARGING AFTER THEY REPLACED MY FAN WHY IS THAT CAN YOU PLEASE GIVE ME ADVICE CAUSE NOW IT WON'T START...
2 Related Answers
Anonymous
  • Posted on Aug 15, 2009
SOURCE: 2003 GMC Envoy XL transmission issue; make loud noise and...
transmition willnot change to second gear
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Aug 29, 2009
SOURCE: I have 2003 gmc envoy my front ac control does not
Need to check to see if the blower motor is running.If it is,but not threw the vents,most likely a vent door actuator motor.The actuator motor in this case would be bad,it is hard to get to,unless you are mechanically inclined,You can do it your self.If the blower motor is bad,just replace it.Check fuses first,and the blower relay.If I can help,let me know.
2003 gmc envoy xl electrical issues
Ali, when you say won't start, do you mean it will not even crank, or does it crank and does not fire? Sounds like a computer or security issue .
To show your appreciation press the helpful button and follow me on fixya for more tips and info.
Battery not charging indicator. What could be my issue?
Who did the testing & did both the
battery & alternator fail at one time?
Auto Zone has a repair facility & did the work?
What codes are present?
Did anyone look at a data base, to see what
the message your getting was & the solution?
1helpful
Battery not charging light after fan clutch replacement
take it your local MIdas or O'riley Auto parts and have them check the light for free!!! It is most likely a coincidence that it happend after another repair get you alternator checked then just have them check your charging system, alternator is between $100 and $200 and that could easaly be the problem
2answers
We have a 2003 yukon denali xl. we have a signal saying battery not charging. we replaced battery and alternator. still won't charge. truck goes completely dead. no lights, radio anything. what el
I'll try to help, everytime something gets replaced on these yukons, that circuit needs to be RESET ! Is there a reset button, on your steering wheel, to reset a variety of functions ? , check owners manual, or call your dealer for better advise
1helpful
With the engine running check the voltage at the battery. You should see more than 13.8 volts and better yet more than 14 volts. If you have 12 volts or less than its pretty likely the alternator is no longer charging.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2003 gmc envoy won't start and cannot remove key
Ignition switch needs to be replaced, common problem.
To get your key out: look under the key on the column cover. You'll either see a hole there or an outline where a hole was supposed to be. If the hole is there, push in the solenoid to release your key. If the hole isn't there, carefully cut or drill the plastic out there, and push the solenoid there. I believe they quit putting the hole there in 03', BUT like mine, you'll see a faint outline in the plastic of a hole.
Add a comment
2helpful
2003 Envoy XL
It is in the front of the engine with the fan mounted to it. It is electronicly controled. If you change it be very careful the radiator is easy to damage. Good Luck
1helpful
All at once? 2003 GMC Envoy XL
have the car scanned for trouble codes and get back to me with the codes. most major parts stores will do this for little or no charge,get back to me with the codes
Top GMC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Mike Lann
Mike Lann
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
