How do I fix this or get bit fixed? Its a hitachi projection tv. I've replaced the bulb the blue on the screen don't move or fade or nothing. It showed up about an year ago when the kids left tv on overnight with a dvd paused for like 9 or 10 hours.
SOURCE: Mitsubishi WS65905 Projection TV
convergance ics and sometimes resistors go bad. call a repairman...
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
SOURCE: blue haze on hitachi 51" tv
Ya so i bought the same tv and have the same blue haze, it is going to cost me over 1000.00 to fix what a waste of over 2000.00 that i paid for it and it doesnt even last 21/2 years!!!
SOURCE: Light on the projection is fading
if the led is fading it waring out and it will need replacing try and **** smith electronics or Radio shack take the clock in with you so they can provide better service for you
SOURCE: hitachi ultravision dlp projection tv
No you need a light engine, possibly covered under a recall, other wise its like your cars block is cracked
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
