Question about Canon imageCLASS MF8170C All-In-One Laser Printer
My Printer started randomly printing blank pages when looking for color. Prints color every now and again, but generally blank. Prints fine when I set to Black/white only.
Replaced the drum2x thinking maybe I had a bad one. Not calling for any of the other color cartridges. Is there a self clean setting?
Mike M
  • Canon Master
  • 3,324 Answers
It is more likely that the settings need to be changed on a print job to job basis in the program you are generating the content from. There are usually defaults set in the software and you need to check these settings every time you print.
Posted on Mar 11, 2015
Printing heavy bars or blank pages
PLEASE REPLACE PRINTER LSU OR HIGH VOLTAGE POWER SUPPLY
Feb 14, 2014 | Samsung SCX-4828FN All-In-One Laser...
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Only prints color--black ink is full, just put in a new cartridge
Instead of trying to change or find a "setting", the fastest resolution is to uninstall and reinstall the Printer, If not sure how, click start, click control panel, on the left of the window if you see switch to classic view, click there, IF XP, click Add/Remove Programs, if VISTA, click programs and features, remove all entries and reinsert install disk and repeat setup
Apr 12, 2009 | Kodak ESP 5 Printer
Prints blank pages
make sure u have the printing options from printer settings set to black only and not colour..
Sep 09, 2008 | Epson Stylus 880 InkJet Color Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
180 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
