98 Road king...Driving along at normal speeds and normal temp it will just cut out. Pull in clutch and pop in neutral it starts right back up... any ideas?? Thanx
to determine the actuall adjustment to the clutch lever run ur machine as normal on the 2nd gear and then reduce the speed teh gear will slip tightn up the lever till tht play goes away ..and do let me know
Will the bike start up without turning off? If you have to turn ignition off then on again before it will start it may be the bank angle sensor gone faulty. This will set NO error codes in memory as it is NOT a recognised fault. ECU simply thinks bike has fallen over and shuts engine down.
Pull the speed sensor from the transmission case and if there are any metal filings on it clean them off and replace it. If there are not filings you may need to replace the sensor. The speedometer head itself or wiring conneftors could be the porblem as well.
to change the final drive belt on your Road King, you must pull the entire primary off. The outer primary cover, the clutch and primary chain, the inner primary, and the starter must come off. Then, you have to remove the rear wheel, remove the shocks, and pull the swing arm out as well. It's a major job.
It's normal for the check engine light to take from 0 to a couple seconds to turn off. The computer runs a system check. Put an oil pressure gauge on the bike and watch it closely. If your pressure drops when the bike loses power, the engine may be locking up from lack of oil. Another possibility is your lean-angle cut-off switch is defective. The switch cuts power to the bike in case you lay it down. Harley also has had problems with their fuel injection system losing power for no apparent reason.
Theres 2 clutch adjustments you can do - one is on the cable, under the boot, the other is at the clutch hub, under the derby cover in the primary. That should take care of the whine and your problem finding neutral. If you get some teflon spray and shoot it generously down the inside of your cable, you are gonna be surprized at how easy it'll pull
