Question about ZEEPAD 7DRK Dual Core 4.2 Purple Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 PUR
Trying to connect using wifi but it will not connect
Posted by Anita Carrick on
Samsung laptop showing connected to wifi but when try to access wifi says problem with connection
Try using the troubleshooting option that usually is offered when you get a network error message. If still does not work after that need more specific info on exact wording, Windows version, whether all wifi connections affected, etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Jun 04, 2016 | Samsung Galaxy Tab Tablet PC
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
I can't connect to wifi and when I can I can't setup my gmail account or any other apps I have try everything I know
I'll give you some help on ANDROID. Go to apps, settings\ WiFi. Turn it on at top of screen. Any available WiFi accounts will show up. Then go to top right push the three dots, click advanced and make your choices. Click back to WiFi screen and click the WiFi you want to connect with, enter the key that your WiFi needs to connect, or use the WPS option if available on you WiFi. If the WiFi has WPS, push the button on the WiFi and connect your tablet or phone by pressing connect.
Nov 29, 2015 | Tablets & eReaders
My Kobo Arc 32, asked for a password, when I tried to try the WiFi. I don't remember setting a password. So, now it's asking for an guest password.
It is not the Kobo that has set the password, rather the router for the wifi that you are trying to connect to. You just need to know the password for the router to let you connect. If a router has no wifi password, it is considered unsecured and ANYONE can access it. So most all routers use password protection. If it is YOUR wifi system, and you no longer know the password, you can change it if you access the router setup for wireless and change the password. Be advised, however, that all devices that connect to the wifi will need to change their passwords as well or not be connected. If it is not your wifi you are trying to connect to, then you need to obtain the wifi password from that wifi system's administrator.
Nov 06, 2015 | Tablets & eReaders
Fix no connection retry error
Sounds like your wifi is turned off. Go to your wifi settings and make sure its on. This is a common mistake for most of tablet users.
Jan 18, 2015 | Tablets & eReaders
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
Dec 27, 2014 | Amazon Kindle Wireless Reading Device
How do I get cnm touchpad 9 to authenticate wifi connection to the internet, what are the correct settings, keeps connecting to bt fon instead.
I am assuming you are on an Android platform, so the first thing you should check is to see if your Wifi is on....Settings, Wifi, then usually there is a on/off switch at the top...if its off turn it on and then try to join the wifi AP. If the wifi is on and your still connecting via bluetooth then shut bluetooth off, settings, bluetooth and try connecting...maybe there is a default setting somewhere forcing you to use the bluetooth ...I'd need to know what OS your using and the version number to give you direct information.
Dec 22, 2014 | Tablets & eReaders
My tablet is saying i am offline and will not connect to Wi-fi
Firstly Check if your WIFI router is working by accessing the WIFI connection from another computer, tablet or phone.
If it does, then use the same WiFi connection settings that it has on your ARCHOS.
You could also try connecting your ARCHOS to a friend's WiFi network and if this works, change your access point parameters to similar ones.
OTHER TROUBLESHOOTING OPTIONS:
1. Check your WiFi router/modem documentation to see if it has a pairing button that needs to be pressed. Some modems have such a button that must be pressed the very first time you try to make a WiFi connection with a new device.
2. If you have to enter a password (a security code of type WEP or WPA) be very careful that you do not confuse a 1 and I (one and letter "I"), a 0 and O (zero and letter "O"), or U and V. These are common mistakes.
3. When entering a security code for your WiFi access, check the box "Show Password" which will allow you to see exactly what you are typing in. This will avoid any mistakes.
4. Some access points use what is known as MAC filtering. That means, the WiFi access point has a list of access numbers (every hardware device has a unique MAC number) which are the only ones allowed to access to the WiFi point. The person managing the WiFi modem/router should shut off this MAC filtering system to see if this solves the problem. It is recommended to shut off MAC filtering in general as this is now known to be an outdated and ineffective system for WiFi security. If you must use it, you can find your device's specific MAC address by going to Settings >Wireless & Networks > Wi-Fi settings > Menu > Advanced. It will look something like 00:16:dc:5e:9e:39.
5. Try temporarily shutting off the encryption system of your WiFi router/modem to see if the problem has to do with the encryption system you are using. The preferred encryption system is the WPA2.
Aug 14, 2014 | Archos Tablets & eReaders
Wont connect to internet even though the wifi says it is connected
It could be because of the amount of devices that are connected to your wifi. Too many devices could put a lot of weight on your bandwith causing the wifi itsself to become slower. Disconnect any devices using wifi in your home that dont need to be on every day and try reseting your modem or router. You could also use a usb cord to get a more direct connection or you might have to upgrade to a faster wifi company. If the problem still continues take your device back and get it fixed, call the number in the troubleshooting guide, or visit the nextbook website and make sure you have your device registered.
Jun 25, 2014 | Nextbook Premium 8 Se Android
My tablet will not connect to my wifi. it connects to just about every other wifi i have tried just not mine. my wifi connects with other devices so i know it works. help!
When you are connecting to other devices it may be using bluetooth. Is the wifi on? does it get an ip address from the router?
Dec 20, 2013 | Tablets & eReaders
ZEEPAD 7DRK Dual Core 4.2 Purple Android Tablet 7 Inch, Multi-Touch, Dual Camera, Wi-Fi May 2014 PUR Logo
41 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Sean Cole
Sean Cole
bobalix
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
