Question about M-Audio Computers & Internet
I need a pin out diagram for audiophile 192. I wand to do myself the break out cable
isidroco
    New Friend:
Measure it myself from original card and cable.
M-Audio Audiophile 192 Pinout
DB25 Male, front view:
01 02 03 04 05 06 07 08 09 10 11 12 13
14 15 16 17 18 19 20 21 22 23 24 25
In and Monitor cables are connected to same pins (so are interchangable):
22 In L Gnd - Monitor L Gnd: iLg
21 In L Tip - Monitor L Tip: iL+
09 In L Med - Monitor L Med: iL-
08 In R Gnd - Monitor R Gnd: iRg
07 In R Tip - Monitor R Tip: iR+
20 In R Med - Monitor R Med: iR-
Main OUT:
19 Out L Gnd: oLg
18 Out L Tip: oL+
06 Out L Med: oL-
05 Out R Gnd: oRg
04 Out R Tip: oR+
17 Out R Med: oR-
Midi (Female connectors):
11 Midi Out 4 mO+
12 Midi Out 2 mOg
24 Midi Out 5 mO-
13 Midi In 4 mI+
25 Midi In 5 mI-
Midi In specifications leave Gnd pin 2 unconnected.
So connector its:
01 02 03 oR+ oRg oL- iR+ iRg iL- 10 mO+ mOg mI+
14 15 16 oR- oL+ oLg iR- iL+ iLg 23 mO- mI-
Posted on May 06, 2019
2 Related Answers
Verne Koti
  • 476 Answers
SOURCE: audiophile 192 sound card driver
If it hasn't installed the device ,
uninstall device and reboot then restart
device should autofind and self install
Let me know how it goes thanks
Please rate me ,,,Cheers
Posted on Jul 24, 2008
digritz
david mcclellan
  • 530 Answers
SOURCE: installation of audiophile 192
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Posted on Dec 03, 2009
2answers
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
4answers
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
M-audio 192 it aborts installation Delta doesn't support my system
it supports all operating systems .. the drivers you are installing may be corrupted here is the link below download drivers and install it
http://driverscollection.com/?H=Delta%20Audiophile%20192&By=M-AUDIO
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Need for driver installer for intel fw8280
Did you check the manufacturer's website?
Or try a driver finder program to scan all devices and find the right drivers.
Hey I've just purchased an M Audio 192, Windows XP; with only a very very quiet signal issuing from either my Monitor Outs or the Main Output to my Stereo speakers; I've even tried putting it through my...
you must go into the cmos and diable the onboard sounds when cp starts hit either f1 or f2 or del key to inter cmos be sure not to disable anything else the sound are usly found at the pirephels esxcuse spleeing
1helpful
4answers
Installation of audiophile 192
1helpful
2answers
M-Audio 192 Sound Card _ No Sound comming out
I was speaking to this custom pc company about my identical problem. Turned out that I had the wrong speaker setting in Windows. It was set to 2.0 when it should have been 5.1 and hey bingo, it worked. Not sure if thats what your problem is but sounds the same. Ted
Audiophile 192 sound card driver
Computers & Internet Logo
Top M-Audio Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Lawrence Oravetz
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
