Question about Proscan 32LA30Q Television
Attached flat antenna to TV via coaxial cable. But TV does not recognize it and I get no signal. Why? It used to work fine on a vable HDMI.
Posted by thieslaw on
2 Related Answers
gopakumarg43
  • 76352 Answers
SOURCE: proscan tv no signal
Digital video processor board [main] is faulty. Replace it.
Posted on Oct 06, 2012
Jim Pattison
  • 1004 Answers
SOURCE: Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
Posted on Jun 05, 2014
How do you connect the IKonvert SC-58 to the tv set
Reviews are bad for this unit :>(
https://www.amazon.com/Supersonic-SC58-Digital-Converter-Box/dp/B00IRL8IBM#customerReviews
You connect it to the television with a HDMI cable or RCA jacks. Coaxial cable input
Converts Over-the-Air Digital Television Signals for Use with Older Standard Definition TVs (480i)
• Receives Free Over-the-Air Digital TV Signals
• Record Live TV Via USB Connection
• Full ATSC Compliant
• Supports Full HD 1080p
• Output Display Resolution 480p/720p/1080i/1080p
• Built-in USB Input
• On-Screen Electronic Program Guide Support
• Supports Closed Caption
• Aspect Ratio: 4:3 &16:9
• Parental Lock Function
• Auto & Manual Scan Finds All Digital Broadcasts
• Signal Input: Coaxial Antenna
• AV Output: HDMI, RCA
Oct 14, 2018 | Televison & Video
Model# ELEFW195. is this flat screen tv. cable ready ?
If you have a free cable TV connection you can connect it to the antenna connection, tune the TV to the channels and it will work. If you are using a subscription TV service you may need a box provided by the subscription provider in which case the connection may be via the HDMI connection. Check with your cable TV supplier for how yours connects.
Jul 03, 2017 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Everything working except I can't get digital channels. It comes up with no signal. But all digital SBS channels are working fine. How could that be.
Is it saying no signal or one moment please? No signal is a dead give away; there isn't any. One moment please can be several things. Low signal or cable box isn't active. How do you have your connection from your cable box set up as? Coaxial cable, RCA, HDMI, or component? Also, make sure whatever connection you're using, connect from you cable box out into your TV's in (type of cable you're using) Make sure you're on the correct input. For example. RCA may be video 1 or 2 depending on where you plugged it in. Hdmi -> may be HDMI 1 or 2. Coaxial may be channel 3 or 4 on your tv set. Hope this helps.
Mar 02, 2011 | Hisense Televison & Video
Can not get the listings for the TV Guide to load. The TV is connected to cable box and tuner with HDMI cables. When I contacted LG they stated that I need to split the cable signal prior to connecting...
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 01, 2009 | LG 50PX4DR 50 in. Plasma TV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Coaxial cable works but not RCA
You have a DEFECTIVE box. There is no 'lock out feature on the Insignia. If your cables are ok, and you've tried it on another TV, then its the box.
Jan 31, 2009 | Televison & Video
Proscan 32LA30Q Television Logo
Top Proscan Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
