Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Looking for a door seal for a Hotpoint Ultima 1200.
Posted by washington_1 on
Barry Coates
  • Hotpoint Master
  • 3,463 Answers
If you have not yet got door seal, then go to www.hotpoint.co.uk.
Please rate my solution.
Thanks.
Posted on Sep 17, 2009
1 Related Answer
shaun taylor
  • 1527 Answers
SOURCE: changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Posted on Sep 06, 2009
Hi My hotpoint washer dryer 1200 ultima has a door fault , saying close door when in fact the door is shut, i have attempted to replace the door lock, but i cannot get the front drum seal off, there seems...
The cap should be just a cover cap. A circle cap with two prones opposite of each other. Try and get a knife and slide it around till you find the connection prones press in and poof should pop out. All it is is a precaution to prevent water from corroding the screw. You should also beable to buy a replace ment very cheap if you happen to break it. Hope it helps. Let me know what happens
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Changing door seal on hotpoint ultima washing machine
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
How do remove front seal on my ultima wf865
Remove top cover, unclip the control board, and unplug the lead to the board, remove screws holding board and remove same.
Remove front panel screws, remove screws holding door lock,remove clamp securing front seal ,remove seal, slide panel up and remove.
Change seal.
Re-assemble in reverse order.
Thanks.
Jul 29, 2009 | Hotpoint Ultima WF865 Front Load Washer
How to remove and replace door seal on a hotpoint wt 741
the door seal are hard to do just take a good look at it befor you take it off you can take the frount panel off the washer to do this job give your self a few hrs so you dont rush
Jun 28, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washer dryer ultima 1200 model WD71S
most like cause is the door interlock is faulty but its one of those jobs that unless you have the right equiptment namely a tester you won't know for sure unless you change it. Could also be the voltage from the control board is't correct so best let someone who knows check it for you.
Mar 22, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
