magicJack pc to phone, free local & long distance calling, magic jack voip phone Logo
Question about magicJack pc to phone, free local & long distance calling, magic jack voip phone
Our magic keeps beeping and then it will cut off and we have to make another call again its not a phone, just hooked to the computer and a phone pluged into it.
Posted by dan walter on
Joe Lane
    New Friend:
  • 43 Answers
Put this in your sipdefault.cnf
# Time Server
sntp_mode: "unicast"
sntp_server: "192.168.0.1" (change this mine is local)
time_zone: "EST" (change this to your time zone)
dst_offset: "1"
dst_start_month: "Mar"
dst_start_day: ""
dst_start_day_of_week: "Sun"
dst_start_week_of_month: "2"
dst_start_time: "02"
dst_stop_month: "Nov"
dst_stop_day: ""
dst_stop_day_of_week: "Sunday"
dst_stop_week_of_month: "1"
dst_stop_time: "2"
dst_auto_adjust: "1"
Posted on Jun 17, 2015
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Will a magic-jack hook to phone line that is spliced to all phones in your house work all phones.
No! the device is designed to work through your computer only, it is not compatible with the rest of your phone system.
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
My phone was working well, every time I plug into my computer, BROKEN STORAGE shows up on. I have brought several different magic jack, thinking it was the magic jack itself.
If you've already gone to magic jack's website and downloaded their updated software then you're looking at a jack reformat. I've had this problem several times with my magic jack and you'll find many different solutions that just don't seem to work and are all very involved. Warning: doing this will lose all your contacts which from my experience is the only way to go to get this problem fixed...and only temporarily mind you until the problem happens again. Keep your contacts elsewhere in the meantime. Go ahead and go to your "My Computer" from your start menu and then take a look at the drive letters that come up while you have the magic jack plugged in...if you try to open them you will notice that one of them will say that the drive needs to be formatted (magic jack creates 2 drive letters for the device) If you see that, go ahead an select yes to format it and doing a quick format with all the default selected options will do the trick. Once it's done formatting, Launch the phone application and you would get to the screen where it asks for your email and password and then you will be logged in. keep this solution in mind whenever it happens again~ Good luck.
ASpecialty4You.com
1helpful
Oven keeps making a BEEPING sound - only way to
This will occur when there is a control fault detected. have the oven control board replaced asap.
Aug 20, 2009 • Ovens
1helpful
Magic jack beeping sound heard by receivers of my calls
You will experience lots of sounds with magic jack, sometimes beeping, sometimes crackling, sometimes it cuts out. They are not reliable. I gave mine up.
MagicJack VOIP sound cuts in and out
Try your magicjack device in another usb port, as they sometimes share an irq internally with other devices, hence the chopped sound. Also make sure your computer is no trying to go into sleep or suspended mode, check the power settings to make sure the system is not shutting down devices in low power or battery mode if using a laptop, make sure the connection speed is good and strong, especially if connected to a laptop, and make sure nothing is hogging the cpu, causing the chopped sound. Also there could be issues with the router. Lastly, perform a firmware upgrade on your magicjack device, restart the machine, and then test it again. Good luck.
1helpful
2answers
Error code F1
I had the same problem and found this post:
http://fixitnow.com/wp/2006/03/11/maytag-amana-jenn-air-and-magic-chef-range-f1-codes/
The oven had been cleaned earlier in the day and the touch pad ribbon connector was shorting. I cleaned it with rubbing alchohol and blow dried the whole board for good measure. Hooked everything back up and haven't had a problem since.
Top magicJack Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
john h
Tom Chichester
Are you a magicJack Computer and Internet Expert? Answer questions, earn points and help others
