Question about Sony PS-LX250H Turntable
I don't use the turntable that much and I thought it might be the belt when it get warm and maybe smaller?
Any infinitesimal change in belt temperature would not cause such a change in speed. The speed of your turntable is governed by an electronic circuit and this is where the trouble is.
The cost of a repair is going to be mostly labor which may exceed the value of the value of the turntable.
Posted on Mar 16, 2015
SOURCE: Speed
The motor for the unit might be dying out. There really aren't any other factors that control the speed/rpm of these belt driven models. So if the belt didn't do the trick, you will have to take it to a service center to test the motor.
Posted on Sep 23, 2007
SOURCE: Turntable speed
most of these were belt driven, if that the case check to see if the lever is connected moving the belt to the slower pully
Posted on Jan 04, 2008
SOURCE: Sony PS-LX250H turntable speed adjustment on underside, how??
Great detective work.
Let's collaborate on this for the benefit of others who may have the same problem.
L.IN should be the point at which the Lead-In groove on the LP would be, where the tonearm will drop to play an LP
RET should be the point at which the tonearm will lift up and RETurn to its rest at the end of the LP
That leaves us with SW. If your source is right this will affect the Speed. I can't imagine what the W stands for.
Since this turntable lacks the traditional strobe light and dots along the platter rim for determining if it's on target speed-wise we have to improvise and make a Strobe Disc.
It has radial marks on it and you place it on the turntable like a record. The lights in your room running at 60hz will make it appear to be stationary if the speed is correct; slowly creeping CW if too fast; CCW if too slow.
Here's a link to a PDF from which you can print your own disc... http://www.extremephono.com/ftp/60Hz.PDF
Here's what you do. Lay the trimmed Strobe Disc on top of a record while it's playing one of the outer tracks. This is because the stylus imparts some drag so we want to factor it in.
Then adjust the screw exactly one turn Clockwise and note how the speed has changed. Trial and error should get you to where you want to be.
Posted on Apr 05, 2009
SOURCE: Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Posted on Jan 26, 2010
SOURCE: How do I manually adjust
Without technical equipment it would be near impossible to get the speed down to the level of a CD. A lot depends on the belt, how much it has been used, for example a new belt might help! The motor of the deck could have a speed setting on it, but even so it would be on the bottom of the deck and you would have to adjust while you were under the turntable. Like being under a car!
Some have speed presets, again under the deck, often covered with a label. Others will have them on the PC board of the deck's power supply section.
On the whole that's one of the flaws with records and decks, they are not as good as CD's.
Posted on Dec 09, 2010
Apr 29, 2014 | Audio Players & Recorders
Mar 02, 2013 | Audio Players & Recorders
Feb 28, 2013 | Audio Players & Recorders
Mar 02, 2011 | Technics SL-1200MK2 Turntable
Dec 16, 2010 | Seth Thomas Pacconi Turntable
Feb 20, 2010 | ION Audio Vinyl Recording Turntable
May 19, 2009 | Audio Technica AT-PL50 Turntable
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Oct 14, 2008 | Technics SL-1210 Turntable
Aug 06, 2007 | Sony PS-LX250H Turntable
May 24, 2014 | Sony PS-LX250H Turntable
May 20, 2014 | Sony PS-LX250H Turntable
May 18, 2014 | Sony PS-LX250H Turntable
181 people viewed this question
