I have error code 0xc05d1281 what does this mean?
ADCSFXworks Printing Center
    New Friend:
  • 79 Answers
This error means "Ink System Failure"
And it means that something went wrong in the ink manager internal printer software.
Try removing all the ink cartridges and then power off and on again the printer
If it asks for inserting the cartridges insert them one by one and see if the error appears, in that case the thing that provoke that error is that specific ink cartridge.
So change the specified ink cartridge.
If you didn't solve with this procedure maybe the printhead failed to do a specified operation, or anyway the printer have a specific error on the mainboard and need assistance
Let me know ;)
Posted on Mar 10, 2015
HP c8180 error code oxc05d1281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d1281-Error-code-for-Photosmart-C8180/td-p/1212853
Apr 10, 2015 | HP Office Equipment & Supplies
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
Error code 0xc05d1281
Try the steps in the following website:HP Website
It may help.
0xc05d1281
A full guide for clearing all 0X error codes can be found here. I would normally paste the solution but there is so much information you may be best checking out the whole thing (with images).
Hope this helps.
Nov 01, 2012 | HP PhotoSmart Office Equipment & Supplies
Display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
95 people viewed this question
Ekse
Marvin
Marvin
