Question about magicJack Plus
Use magic jack on my kindle fire?
We already have Magic Jack Plus on our home phone. Someone said there is a way to use it on my Kindle Fire. Is this true? If so, please tell me how to do it?
Harry Husted
    New Friend:
  • 37 Answers
No. There the USB port on the Kindle Fire doesn't host any signal. It is strictly used as a port to plug an external storage device into.
Posted on Mar 11, 2015
Can you call someone on a tablet
There is one easy way, but you need Google play Services in order to work. Hangouts have a dialer, which you can use to make calls with a tablets.
You can also check other apps that allows you to make calls, try first with magic Jack, this is an app that lets you make calls from any devices that is compatible. If for any reason Amazon App Store doesn't have it, you can download the APK file stright to the table as long as you have unknown sources tick in the security settings.
Dec 20, 2014 | Amazon Kindle Fire HDX 7
Magic jack customer service
If your tv has internet access and you can run their software on it then it will, otherwise no.
Aug 30, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
My kindle fire 4g the volume is turned up but has no sound
Since it is basically sealed there is not much you can do about it. Is it still under warrentee?
However I once also had this same problem. It must have been some dirt or corrosion in the earphone jack. Try taking an external earphone and keep putting the tip into the jack several times. If it starts to work then that was your problem. If not then you need to contact Kindle and ask for repair.
Hope that it is just the earphone jack.
Good luck,
Marty
Apr 26, 2014 | Kindle Fire HD 8.9" 32GB, 4G Wifi
Kindle fire hd tablet won't charge up
1) Plug it into a different USB port on your pc;
2) Use a different USB charger - look to see if the one supplied with your 'phone has the common Micro USB jack;
Fire's take about 14-16 hours to charge from a pc and 3-5 from the wall,
Jan 27, 2014 | Amazon Kindle Fire HD
Bose Wave Radio/Kindle Fire
Yes, all you need is a standard audio adapter cable that plugs into the earbud jack on the kindle and into the "variable in" jacks on the back of the Bose. (male stereo 1/8" plug to a pair of male RCA/phono plugs).
Dec 11, 2013 | Bose Black Wave Am/fm Radio W/ Remote -...
magicJack Plus Logo
212 people viewed this question
Top magicJack Office Equipment & Supplies Experts
ray gallant
C. David Graves
Are you a magicJack Office Equipment and Supply Expert? Answer questions, earn points and help others
