Google Nexus 7 Logo
A
Anonymous Posted on Mar 10, 2015
Wont turn on or charge up.
White light flashes 5 times and nothing else happens
Paul Jones
Level 2:
Sergeant:
  • Expert 215 Answers
  • Posted on Mar 11, 2015
Paul Jones
Expert
Level 2:
Sergeant:
Answers
215
Questions
0
Helped
47570
Points
557
Reinstall the OS after charging with powerful charger min 1.5 Amp
http://download.cyanogenmod.org
Why wont my nextbook flexx 11 charge or turn on
Take it to a repair shop!!! Never use the wrong charger on computer equipment. Damage can occur.
My RCA tablet wont charge I have to lean it against something to charge WHY??
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
www.tomsguide.com/forum/id-1869519/tablet-turn.html
Oct 17, 2015 - 50 posts - ‎43 authors
We often get questions such as " My tablet has stopped charging & I have .... Maybe the case was designed badly and the power button won't ..... Something must havelocked the Memopad open and ran the battery completely down. ..... I had RCA send a replacement tablet after it happened the first time.Missing: lean
Why can't I get my RCA tablet rct6077w2 charge or turn on ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Oct 8, 2014 - 4 posts - ‎1 author
Screen will not light up at all. Took it to store, got brief charge there. At home, now, no indication of power.....Missing: lean
How to Calibrate Your Mac, iPhone, or iPad Battery ...
www.macblend.com/how-to-calibrate-your-mac-iphone-or-ipad-battery/
Mar 14, 2012 - The iPad and other tablets draw more current to charge quickly then a lot of other USB devices ..... Also, it's not something you should have to do frequently. ... iPad 2 will not charge shows battery in red with electrical symbol and plug symbols flashing on ..... I'd lean against trying to restore if it won't stay on.
My samsung galaxy tab wont charge at all, why? - Ask Me Fast
www.askmefast.com > ... > Charge
1helpful
3answers
Nexus 7 tablet flashing white light
I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
HD Nook wont light up could it the LCD or power switch?
my nook tablet shows the green light that it's fully charged but when trying to turn it on nothing happens the screen does not com on or the nook symbol does not light up . can any one help me out here
Sep 28, 2013 • Nook HD+
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
2helpful
I have been trying to turn on my galaxy tab but it just wont turn on. I have tried charging it for a full day but still nothing. i dont even know if it is charging.
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
2helpful
2answers
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
3helpful
2answers
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Top Google Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
