Question about DISH Network Televison & Video
Sky code for proscan plded3273-uk - DISH Network Televison & Video
1 Related Answer
gopakumarg43
  • 76407 Answers
SOURCE: Hi I'm in need of a proscan code for my sky remote
0028,0027,0022.0021. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Posted on Jun 21, 2014
Whats the sky remote code for my proscan tv.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 15, 2017 | Proscan Televison & Video
Need a REV.9F sky remote code for PROSCAN PLDED3273-UK, need it asap please
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 26, 2016 | Proscan Televison & Video
Can I buy a remote for this tv
Hi, saw this is posted on Argos site giving the code for proscan TV as Curtis TV to use a Sky Remote.... "SKY>SERVICES>PROGRAM REMOTE> "I don't know code"> select CURTIS as make and first in list should be 2287 or 2587 . Worked for me. Curtis is the maker of the Proscan". If it helps you the link is http://answers.argos.co.uk/answers/1493-en_gb/product/3169986/questions.htm
Jan 08, 2016 | Proscan 32LB30QD 32 in. LCD TV
Need sky remote code for proscan tv dvd
try these
  • Proscan 0047 0747 1347 0030 1922
  • can you look inside battery compartment of your remote and see what rev it is should be rev 8 to work with newer tv,s
Mar 27, 2015 | Proscan Televison & Video
Sky remote codefor proscan tv
0102 0112 0191 0194 0210 0345 0366. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Sep 30, 2014 | Proscan Televison & Video
Hi I'm in need of a proscan code for my sky remote version 9f for my proscan plded4022-uk. I would be very great full for any help . Cheers
Jun 20, 2014 | Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Can't find code for Sky remote for LG M227WDP LCD 22 TV
I just had to solve this problem. Answer for my M227WDP with a Rev 8 remote was 0206.
My source and instructions are here: http://www.skyuser.co.uk/forum/sky-sky-tv/15406-common-tv-codes-your-sky-remote.html
May 17, 2010 | LG Televison & Video
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
Tv code for umc s19/2 for sky remote
it would appear that you need to have a version 8 remote for the UMC tvs the code is available here
http://www.satcure.co.uk/tech/digicode2.htm#mycode
Jan 21, 2008 | Televison & Video
Televison & Video Logo
106 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
