Question about Metra Car Audio & Video
Ok first ? Is on my ukulele 6.2 double din the date and time does not work properly it will not same the time and date and second ? Is my metra axxess Aws does not work for ouku how can I program this to work
2 Related Answers
davis_keith1
davis_keith1
SOURCE: Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Posted on Mar 01, 2013
psrigley
paul srigley
  • 337 Answers
SOURCE: I've got an Ouku double din car radio/DVD
recheck install possible loose wire touching metal?
Posted on Jan 05, 2015
I need a wiring diaphragm on the pyle pldn73i and a chevy silervado 2005
Download the manual on this page:
http://www.pyleaudio.com/sku/pldn73i/7-double-din-tft-touch-screen-dvdvcdcdmp3mp4cd-rusbsd-mmc-card-slotamfmipod-connector
There are way too many ways to wire this unit to other components. You can buy a GM wiring harness and integration box to fit your truck that will get you power and factory speaker wires to connect to the unit. If you plan on using navigation or amplifiers, those and other options are custom and will vary with your needs. Check out the metra pages to fathom the possibilities.
Metra 95 2001 Double DIN Installation Dash Kit for Select 1990 Up GM...
Metra Online
Metra Online
Dec 20, 2014 | Car Audio & Video
Why won't the tail lights on one side of my 2011 kia sorrento come on?
Put the driver side bulb in the passenger side, if it works, get a new bulb.
Apr 25, 2014 | Metra Kia Sorrento 2011 And Newer Car...
Metra wiring diagrams 70-1761
I believe that the orange dimmer wire should not be connected to anything. I taped my orange wire and left it unconnected and it worked.
Dec 13, 2013 | Pioneer FH-X700BT Double-DIN Car Stereo...
How set timing?
1. Open Date and Time by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
2.
Click the Date and Time tab, and then click Change date and time. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation
3. In the Date and Time Settings dialog box, do one or more of the following:
a) To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
b) To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
c) To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
4. When you have finished changing the time settings, click OK.
5. To change the time zone, click Change time zone.
6. In the Time Zone Settings dialog box, click your current time zone in the list, and then click OK.
7. Click OK.
Hope this helps.
Apr 14, 2011 | Computers & Internet
Do I need a housing to replace stock stereo? Or will this just fit in
There are two types of receivers. Double-DIN and single-DIN. Double-DIN is easy to see as it is DOUBLE the SINGLE-DIN's height. If your vechile is a single-DIN it will only be about 3-4 inches tall, while the DOUBLE-DIN is doulbe that 6-8inches tall.
If you have a DOUBLE-DIN in your car and are installing a SINGLE-DIN you will need a housing.
If you have a SINGLE-DIN in the vechile you will not be able to install a DOUBLE-DIN without heavy moddification and cutting.
Please rate if this helped :)
Mar 29, 2011 | Denon Car Audio & Video
I want to replace my Pontiac G6 radio. But I want to keep my "info center" display intact. Is that possible?
There is a kit from Metra called the Metra 99-3303 kit that takes the double din area of the stock stereo and converts it into an info center/single din. Cost is about $123 on ebay.
Aug 20, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Aftermarket double din install having problems with int. dash lights,locks
I had soved my problem... That was stupid.. The cause is that I tried to connect the (illumination +) and the (illumination -) wires togetter on the dimmer wire of my double din unit. That make a short cut and blow the litening fuse (fuse 13 on passenger side fuse panel). I replaced correctly the wiring, keeping the (illumination +) wire unused. That solve my problem but, however I get back my dash illumination, I can't adjust the lightning level... I thing I have a problem with the level switch.. It don't matter to me but if you get the same problem and solve it, please tell me your solution.
Regards
jerome
Jun 02, 2009 | 2001 Acura 3.2CL
Will this stereo work in the cavalier?
You will require an installation kit. Your car has a double DIN opening and the AR5500 is single DIN. Other than that, the installation should be as normal aftermarket.
You'll also need a wiring harness. According to Installer.com, the Metra part number is 71-2003-1.
Mar 25, 2009 | JVC Arsenal KD-AR5500 CD Player
Car Audio & Video Logo
51 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
