Question about Staples SPL-P500 Printing Calculator
Constant mode on SPL-P500
What buttons or switches makes constant mode work?
Posted by Nikki Boehler on
Where can I find a user manuel for SPL-P500 calculator?
Google (brand)(SPL-P500)(manual) without parens.
Jun 18, 2018 | Office Equipment & Supplies
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
How do I load the paper in my SPL-P500 calculator?
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
Feb 13, 2015 | Staples SPL-P500 Printing Calculator
My shutter release button on my Nikon P500 is not working. I press it half way and it will focus, but, when I press it full down it will not capture the picture. It started happening suddenly last week....
Try pressing the "Menu" button and disable "Active-D Lighting", also try setting the "Autofocus mode" to "Single". When the camera is off, press the shutter release and twist with the zoom know back and forth. Hopefully that fixes it! It worked for my P500 with the same problem.
Sep 25, 2013 | Nikon Cameras
How to change ink rollers in calculator
How do you change ink in the Staples SPL-P500?
Jan 17, 2013 | Staples SPLP500 Scientific Calculator
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
May 02, 2011 | Office Equipment & Supplies
Staples SPL-P500 Printing Calculator Logo
150 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
