No, they are rather difficult in fact. They are glued quite solidly to the frame and great care must be taken during removal to avoid damage to the frame and the electronics inside. Also, you will most certainly break the screen even more during the removal process and there is greater risk of cuts from the broken glass. You can find videos on YouTube showing the process, and some of these guys make it look easy, but remember they do hundreds of them, so be prepared for failure if you try it yourself. Your chances are 50-50 at best if you've never attempted anything like this before.
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
you cant but some cell repair shop can weird i just put my phone in for the same thing mine was cracked for the longest time but i still used it then the phone screen one day went black so i asked a friend he told me were and for only 20 bucks SWEET so they look at it and tell me it would be $120 bucks i asked why for my friend
told me 20 he told me that i had broke both the upper and lower glass he told me that upper glass only is 20 but both are 120 thats for a GS3. so on a fire is more money for bigger screen so if u still see something careful and to much heat would crack it.do some research look around compare prices look for the good price with great workmanship hope this
I've done several Samsungs, a couple of Apples and a Nextbook. I've never done an Acer but I'm guessing it's not too difficult.
Look up YouTube videos on the subject. You can probably find one for the exact device you have.
If the image on your tablet still looks perfect but the glass in front of it is cracked, then you only have to replace the digitizer glass. The screen is behind that. If you have to replace both, try to purchase an assembled package because it will be easier.
Typically, the image screen is fastened to the tablet frame with double-faced tape around the edges. Then another layer of double-faced tape goes around the perimeter of the image screen and the digitizer is stuck onto that. Getting things apart involves using a hair dryer and several little plastic pry tools (some of which look like pry-bars with a handle and some of which look like guitar picks) to separate the glass parts from the heat softened adhesive. I've found that having several single-edge razor blades is also handy as long as you don't slip and push it into your finger.
When you replace the adhesive between the screen glass and the digitizer glass, make sure you don't leave any gaps in the adhesive. Pressing on the front digitizer glass oil-cans it in and out and if you leave any gaps in the adhesive, dust will get sucked in between the sheets of glass.
By the way, I will NEVER do a Nextbook again--at least I wouldn't replace just the glass. They don't use double-faced tape at the factory. The glass was somehow bonded directly to an aluminum frame. Much of the glass I scraped off the frame only came off when pulverized into powder. I would buy the replacement glass already bonded to the aluminum and just snap that on. Probably wouldn't be cheap.
The screen replacement is available at Amazon. As stated in the description, no instructions included. Nice set of tools included; most not needed. Installation is pretty intuitive; once you see the new screen, you realize that it attaches to the front bevel with adhesive tape, with one electrical connection. You must remove the broken screen basically by gently prying around the edges with tool of your choice. I did see a video of someone using a heat gun to soften the adhesive, but I dared not and used a small hairdryer on occasion. Lots of broken glass pieces will be created, wear safety glasses and work on a protected surface. If I were to do it again, I'd use a shallow cardboard box like the ones on the bottom of packs of soda. This will prevent glass escaping. Be VERY careful when working near the LCD screen, it does scratch easily. Don't worry about the cable, just cut it when removing old glass. Once all glass removed, the Trio will snap open with slight pressure on metal tabs. NO screws involved. Clean bezel well, remove old cable, install new one , reinstall the power and volume piece at the top and snap case together. Simply replace screen by removing adhesive tape and gently pressing screen it in around edges. I think the new screen works better than the original. Be sure both new screen and LCD are clean before the final install. That's how I did it; others might have a better way. Be patient and careful about all the broken glass and it should work fine. Good Buy for money, ships from China but does not take long to get to US. Tracking info is included with the shipping confirmation.
Sounds like a rough one. Repair the crack? @ things ... Replace the glass and or the screen.You do not want to get any glue or used for that purpose. The glass is to protect the screenso, it would be best to look into replacing the glass. It might be part of the screen itself.
Good Luck-Ned-
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
this is a broken Lcd (the screen is distorted by the lines or no picture at all)
this is just a broken digitiser (the screen below the broken glass works fine )
kathee, I think you have to have manufacturer authorized service place to replace the glass. Check manual re: the procedure and if still covered under warranty. I know the feeling.
I have found new screens for the Kurio 7S, however I do not believe that anyone is selling the LCD screens for the 4s at this time. If is only the front glass that is broken, these can be found on Ebay.
I don't own one, but I'm guessing it has a glass-like layer over an LCD display. The first step would be to figure out if it is the glass that is cracked, which I'm assuming is the case, or if the LCD is what is broken. In either case you will need to find a replacement part. I've had good luck using http://froogle.google.com or eBay to find similar replacement parts. Just search for your devices model number plus screen. After you have the part you need it should be a simple disassemble, replace, reassemble procedure. Hope this helps.
