You can try to pull and twist on the lens as you turn it on. Sometime this will work. Do it carefully. Sometimes the lens jumps out of the track, and may be able to be put back with some careful help.
If not, sell as a used as is or repair camera on a site such as Amazon on Ebay.
Hi, To repair Tascam Us-122 errors, use this software package: PC Health Advisor. This repair tool has been proven to identify and fix Tascam Us-122 errors and other Windows problems with very high efficiency.
This error is due to some fault in alignment of the lens. This is a hardware problem. Hence, i will recommend you to take it to nearest service center and hand over it to some technical expert guys. Trying to resolve it on your own might worsen the issue.
Hope this will help you. If you need more information on this, please do write to us.
Hey blondgal12,
From your description you should most likely have your camera looked at by an authorized service technician and get and estimate on a repair done. The manufacturer usually has a list of authorized service technicians in your local area, or you could try looking in the yellow pages. I hope this helps!
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
