SOURCE: TI-30xa Calculator Reciprocal Key
It does. For instance, to get the reciprocal of 4, enter the following sequence: 4 [1/x] (this last key to be found third row down, second black key in). The decimal 0.25 will appear as the result. Convert this, if you want, to the fraction 1/4 by pressing the yellow function key [2nd], then {F<>D] located bottom, far left. Hope that's what you wanted!
SOURCE: how to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
SOURCE: TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
SOURCE: cant get M2 off of my TI-30XA calculator
Remove the six screws on the back cover. After the batteries are installed you need to reset the board. There is a little reset area that needs to be shorted to get the calculator back to normal. Look closely at the circuit board- You'll see a little circle next to the word reset. Its near the middle of the board. Wet your finger- press it on the circle. It should short. Blow it dry with your breath. It should work...
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
