Question about Sony KP-53HS10 TV
Protective circuitry 54142F CC PCB
The problem with my TV has been diagnosed as this protective circuit. Where can I get a new or rebuilt board?
Posted by dave11384 on
Eugene Merritt
    Sergeant:
    Champion:
  • 298 Answers
Have you tried http://www.ptscorp.com/television.html?
Posted on Nov 13, 2007
What is a pcb printed circuit board and where are they located on a th-50px80u plasma tv
A PCB Printed circuit board is every single board in your TV. That is what PCB stands for Printed Circuit Board.
Jul 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
Aug 01, 2008 | Televison & Video
Toshiba TP55F81 going into protection mode
Sir,
Since you have recently purchased that TV... It is best to return it have it changed with a new one... It has still a warranty, right? So why give yourself a problem... It is your right as a customer to get satisfied with what was bought. Remember you pay them for that... Exercise your right!
Go!
Feb 01, 2008 | Televison & Video
The tv had no power so I put a fuse in where the power cord is and it fries out when I plug it in. Its the same fuse that came out of there. Is there a - & + to the fuse.? thank you
There is no positive or negative polarity to a fuse. A fuse is just an in circuit protective device designed to blow when there is excessive current flow. A shorting transitor, coil or numerous other components in the power supply circuitry can cause this. Take power supply to television store, this will save you a fee from them having to come out, and have them diagnose the power supply, which they are good at. You might want to consider going online and ordering a new power supply.
Apr 03, 2011 | ViewSonic N2751W 27 in. LCD Television
I have a 609 Intuitive washer that was dead. Controller fuse was blown, pump control FETs shorted out. Another smaller chip in pump control circuitry obviously dead (small crater in the top). Corrosion...
i just love these machines they are not the best but there great when they work correctly. ok yes the most common problem with the f/p washers is they blow there power control boards the reason why is this there is no power short protection in the pcb have you ever unplugged the washer lifted the lid and turned by hand the barrel and seen that the lights on the control light up it allows the capstan drive motor to reverse its poer back to the board when the washer spins too fast it imt/s too much power back to the pcb. your completly ok to fit the control board it wont burn out 32 ohms on the pump is great give it a little spray of wd-40 anti corosive oil spray now the impulse reader on the side of the barrel small circuit board that must be clean and free of water marks and dust rust e.t.c then the drive break will respond faster stopping pcb burn out do this every 6 months
merry christmas
sonic boom electronics australia
please take the time to rank this advice
thanks
Dec 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Sony trinitron xbr screen periodically goes black. The audio stays on but the video cuts out.
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Feb 20, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
You will be watching the tv and the picture will go out, you have sound but no picture. If you turn it off for awhile it will come back on. Mitsubishi VS5043
Howdy,
Cause 1
1. REPLACE L5A00,IF COIL IS WRAPPED IN BLACK TAPE,WITH PT#351P138020, (THE NEW COIL SHOULD BE WRAPPED WITH YELLOW TAPE).THIS IS LOCATED ON THE MAIN-PCB.
2. CHECK FOR LEAKEY D5A21, PART # 264P045040, IN THE BEAM PROTECTION CIRCUIT ON THE MAIN PCB
3. CHECK PIN 6 OFF IC5A01 FOR 22.2 VOLTS DC IF LOW CHECK D5A09, PART # 264P244030 ON THE MAIN PCB.
4.
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, Big IRISH.
Nov 22, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mits VS-6071 Repairman removed a part and left never came back
it might be the digital tuner board, or an audio board did it come from the front or rear of the TV can you post a pic of it?
Dec 18, 2006 | Mitsubishi VS-60719 60" Rear Projection...
Sony KP-53HS10 TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
