Question about Xerox Phaser 7400/DX Laser Printer
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Posted by Chad Munson on
James
    Problem Solver:
  • 19 Answers
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Posted on Mar 10, 2015
Colors do not align
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Nov 03, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
I have a philips 60PL9200 and the color is messed up
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 31, 2010 | Philips Televison & Video
Xerox Phaser 8400 gets no power
I have been hesitating on answering this because people hang me out to dry on phaser printers when I give them good info. But here goes.
What you can try is go to the back of the machine, whre eh on off switch is located. there are 2 larger thumb screws you twist to align with the back frame. That holds the main board in place, Losten them, remove the main board, reseat the RAM memory into its slots, re insert the main board and try turning it on. If that doesn't work the most likely problem, ( 90 % likely) is the electronics module. And I am sure you did not pay as much for the machine as an electronics module would cost, Generally they are over $1000. Best price.
Jan 21, 2009 | Xerox Phaser 8400 Laser Printer
Message on fax reads "remove and check color cartridge"
i,ve replaced my set top box remote with a universal one but it does not operate it can you suggest anything !
durabrand cg5660-m set top box & the new remote is total control 4. can you help
Nov 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 7400/DX Laser Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
