Vacuums Logo
S
Susan Opatka Posted on Mar 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I use my Powerglide Pet bagged vacuum cleaner, the debris does not go into the bag but on top of it. What should I do?
Model Number 38631 1234000211S. I tried to reinstall the vacuum cleaner bag.
gbob59
Level 3:
  • Top Master 3,063 Answers
  • Posted on Mar 09, 2015
gbob59
Top Master
Level 3:
Answers
3063
Questions
Helped
705141
Points
10419
Usually there is a "seal" to make sure the dirt goes into the filter.
I guess the air flow is bypassing the seal somehow. Is the seal clean, is it in good condition?
Are you sure you have the right bag?
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 • Vacuums
2answers
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
2answers
Why is the vacuumed debris skipping the bag and landing straight in the canister?
damage to the hose end or the rubber on the bag isnt lining up with the hose end,,,in backwards?????????
2answers
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 • Vacuums
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
1helpful
I can't get replacement bags for my Bosch Premium 1300 W vacuum cleaner.
Greetings from GoVacuum,
Your Bosch Premium canister vacuum cleaner uses Bosch Style P Bags.
We carry 2 different types of Bosch Type G bags for your vacuum cleaner.
We have the genuine Bosch Bags Available for Purchase Here;
Bosch Type P MEGAfilt™ Super TEX Vacuum Cleaner Bags
And also in bulk buy here;
3 Pack Bundle Pack of Bosch Style P Vacuum Cleaner Bags Part #BBZ52AFP2U
And we also carry a generic paper style bag that doesn't filter as well as the cloth Bosch genuine bags, but is suitable if you don't have any breathing issues or allergies in your home. Here are the Bosch generic P bags;
Bosch Type "P" Canister Vacuum Bags Generic
I hope that this information was helpful to you. If this helped you, please be sure to rate this as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of my answer.
Feel free to email me at [email protected] if you have any questions or need further help with your Bosch canister vacuum.
Thank you so much,
Chris Jones
GoVacuum.com
1helpful
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
4helpful
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Top Top Vacuums Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
ADMIN Eric
ADMIN Eric
Are you a Top Vacuum Expert? Answer questions, earn points and help others
