Question about Yamaha Electrical Supplies
On my yamaha yg650de generator - Yamaha Electrical Supplies
Posted by john wolcott on
YG650DE Yamaha generator. Fires up perfectly, then shuts down after a minute. Will fire up again, run about 1 minute then shut down. Same thing over and over. changed out gas and oil. Help please
Since most generators are seldom used, gas left in the carburetor gunks up and stops up the passages.
Take lots of pix of the assembly. Pull the carb, remove the bowl and spray carb cleaner in all the holes you see. Don't let it back spray into your eyes. Wear safety glasses. Some holes/orifices may need to have a soft wire passed thru them.
Next time you store your generator, drain the gas, run the generator til all the gas is out of the carb. If you can get to the bowl w/o removing the carb, pull the bowl and spray the bowl and underside of the carb w/carb cleaner and reassemble.
Sep 11, 2017 | Yamaha Electrical Supplies
Yamaha re2500 no oil flowing to valve train?
my yamaha generator will not start/electric) it's dead. is there a fuse on these
Nov 30, 2010 | Yamaha 2500 Watt Industrial Inverter...
I have a yamaha 3000isb generator. checking
That sucks! Maybe it's because your a fireman! LOL
May 08, 2010 | Yamaha EF2400iS Portable Generator
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Yamaha Generator YG 4000 Dies when load is applied.
turn the throtle knob to while checking voltage & hertz
Jun 05, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
Electrical Supplies Logo
222 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
