Coffee Makers & Espresso Machines Logo
J
Judit A Cradic Posted on Mar 09, 2015
I need to buy a dripan for my Santa Fe Quesadilla Maker
Please let me know if I can buy the drip pan
Paul Hoover
Level 1:
Problem Solver:
  • Contributor 34 Answers
  • Posted on Mar 09, 2015
 Paul Hoover
Contributor
Level 1:
Problem Solver:
Answers
34
Questions
0
Helped
3607
Points
65
Try emailing [email protected]. I believe they manufacture your Quesadilla Maker. They are a Canadian company, you can also check to see if there is a local service center in your area by clicking this link: http://www.salton.com/us/support.html#answer3 then find the place where it says "Please contact any of our Service Center about warranty, repairs or parts" and click the words "Service Centers" which will pull up a locator.
If you need further help, reach me via phone at https://www.6ya.com/expert/paul_0c66f8a4b832f53f
2005 HYUNDAI SANTA FE 3.5l. SPECS for IGNITION TIMING please?
Question edited for clarity and spelling of the maker 'HyunAdai'.
Question moved to model category.
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
Ignition timing is fully automatic based on CDI ignition, the crankshaft and camshaft sensors and is checked and adjusted by the ECM.
You don't say why you want to know this and there is bound to be more to the story? But you need an auto electrician and a pro grade scan tool computer to diagnose what issue you have.
https://www.google.ca/search?q=auto+electrician+near+me
https://www.google.com/search?q=2005+HYUNDAI+SANTA+FE+3.5l.+SPECS+for+IGNITION+TIMING
I have a new shift solenoid for it, do I need to drop the whole transmission to replace it or just the pan?
Just the pan usually . How do you know which solenoid ? There are five of them inside . Normally when one goes out it sets a check engine light an a DTC - diagnostic trouble code .
The latch broke, need new one
Here is a listing of sellers on ebay for this item.
http://www.ebay.com/bhp/santa-fe-quesadilla-maker
2answers
How do i change the transmission oil on my hyundai santa fe 2001 v4
When it comes to changing the tranny fluid there's usually only 2 options. If your pan has a drain plug, remove it same as you would when doing an oil change. If not, you have to remove all the bolts on the pan to drain and replace it.
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
I need the removable drip tray from the salton santa fe quesadilla maker
Contact Salton at their website. They should have parts available.
May 13, 2011 • Vacuums
8helpful
2answers
HOW TO CHANGE OIL ON A 2002 HYUNDAI SANTA FE. IM 19 YRS OLD AND WOULD LIKE TO HELP MY GIRLFRIEND AND CHANGE IT FOR HER. A DETAILED DRAWING POINTING OUT THE OIL CAP AND THE DRAINAGE AND FILTER FROM...
Lift your Hyundai Santa Fe using a jack and then place the car on jack stands. If you don't have jack stands, drive the car onto a set of wheel ramps.
Pop the hood and remove the dipstick and oil filler cap. The dipstick is near the front engine compartment with the oil filler nearby.
Gather an oil drip pan, a 17-mm wrench, oil filter wrench, cleaning cloths and a new oil filter. Slide under your Santa Fe.
Change the Oil
  • Locate the oil filter and oil drain plug underneath the car. The drain plug is on the bottom of the oil pan, and the filter is to the side of the oil pan.
  • Remove the oil drain plug using the 17mm wrench. Pull the plug out quickly and let the oil drain for 10 to 15 minutes. Check the gaskets and threads for damage. Replace these components, if necessary.
  • Take off the oil filter using an oil filter wrench. Dump the old oil into the oil drip pan and put on the new oil filter. Tighten the oil filter by hand, and then replace the oil drain plug using the wrench. Clean off the excess oil.
  • Go under the hood and add oil. Turn on the engine and check the oil pressure gauge to make sure it rises. Let your Santa Fe run for a minute.
  • Lower your Hyundai Santa Fe and turn off the engine. Take an oil reading on the dipstick. If the oil level isn't at full, add a bit more oil.
Thanks
Kinldy rate the answer
Smith
14helpful
4answers
Owners manual
I've tried repeatedly to access Salton's (the maker's) website, but the section of it dealing with brands is down. It appears they've changed hands. I found the manual online to a very similar appliance, though, the El Paso Quesadilla Maker. The pictures in it look eerily like my Santa Fe model, and it has some good sounding recipes to boot. The address is:
http://www.elpasochile.com/Quesadilla1.pdf
TP
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
