Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
A
Anonymous Posted on Mar 09, 2015
Is dongle available
Is software mod available to run with or with out dongle
Susan Kotarski
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 12 Answers
  • Posted on Mar 10, 2015
Susan Kotarski
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
12
Questions
Helped
3846
Points
30
I am not aware of any security software designed for this sewing machines.
Which artlink is compatible window7, aurora 430 and embroidery unit.Artlink6 is working but doesn't allow me to write to machine.Editor lite v4 doesn't pick up dongle.Nothing wrong with USBports
This sounds more like a driver issue than a software problem. The ArtLink 6 software CD that came with the Aurora 430 had drivers for XP and Windows Vista. However, these drivers may have only been for the 32-bit OS. Windows 7 is the first version of the OS to have had a large number of 64-bit installations.
The latest drivers for the Aurora 430 is available here: https://berninaofamerica.zendesk.com/hc/en-us/articles/200183069-Aurora-Driver-Windows-Vista-7-and-8- . You will need to install two drivers; follow the directions on the site. Make sure that the USB cable is good and that you aren't using a USB hub.
If you have installed the drivers and the ArtLink 6 software still isn't working, ArtLink 7 is fully compatible with Windows 7 and the Aurora sewing machines. The only download site for this software that I've found is https://www.bernina.com/en-CA/Products-CA/BERNINA-products/Software-Designs/BERNINA-Embroidery-software/Advanced-Embroidery-Software/ArtLink-Seven . ArtLink 8 is also Windows 7 compatible. However, I haven't found any documentation on the supported sewing machines.
The driver issue also applies to the dongle. Try this site: https://www.bernina.com/he-IL/Support-IL/Software-he/Embroidery-Software/Dongle-Driver . However, since you have the Editor Lite v4, this dongle may not be supported under Windows 7. The dongle driver is not updated regularly. For some information about the software limitations, see https://www.bernina.com/he-IL/Support-IL/FAQ-he/Software-he/Can-I-update-my-BERNINA-embroidery-software-Editor .
I hope this helps.
(There is a patch for the v5 software to run properly under Windows 7. There isn't one for the Editor Lite v4 to the best of my knowledge.)
1helpful
Lost security dongle to install and open explorations lite software for emotions sewing machine
from the maker of the software. They are not freely available on the market and are "KEYED" to the software. So one dongle will not work with another's software.
3helpful
2answers
How to run 5D embroidery software without the dongle
take it to the dealer with your SN and receipt the dealer can get you a new dealer for about $100, but if you are not the original owner who registered the SN, it is a copyright violation and you are SOL
1helpful
I have a reader-writer box for a Viking Rose machine that is missing the dongle. Is there any place I could get just the dongle?
The dongle is only available with the software when you buy it. The dongle alone doesn't run the reader/writer box. The dongle is the code key for the software that allows you to send designs to the reader/writer. So purchasing new software (which also gets you the new dongle) is what you'll need to do if you want to send designs to the programmable card. Another issue you may have is that the older reader /writer box that uses a parallel port hook up, doesn't work with the new software. So if you have an old reader /writer, you'll also need a new usb reader / writer box. The new reader / writer also comes with a new programmable card.
Dongle
I believe that the information that you have been given is correct. The VIP dongle is no longer available.
As for the second part of the question, do you have a damaged dongle or has it been lost completely? If it has been lost, there is no way to replace it without buying a new software package.
1helpful
Digitizer 2000 - Dongle ?
I'm going to assume that you mean the Digitizer 2000 software.
Unfortunately, your best bet will be to either wait and see if another copy (complete with dongle) shows up on eBay or upgrade to the Digitizer 10000 version (while Customizer 10000 is NOT compatible with the MC9000, Digitizer 10000 IS), either via your local dealer or snagging it on eBay.
Right now, there's two auctions on eBay for the Dig 10000. It seems to run roughly around $300-400.
Best of luck to you!
1helpful
3answers
What is a dongle? My version 3 keeps saying attach dongle but I don't know waht that is.
A dongle is a usb plug in used for mobile broadband connections and should be available from your mobile phone shop!
Hope this helps
from Evelybird
12answers
Loaded 3D Embroidery software on computer but will not recognize the dongle plugged in to the usb port. Drivers for dongle did not automatically load, went online to find a HASP file (driver I think) and...
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
2answers
Dongle
Hello. No, the only way you are going to get this to work is to replace the software with new ones, as all software come with different dongle numbers. The dongle numbers are specifically for the software that you have, you can't even change dongles. Can you get in touch with the seller to give you the dongle? I have a set of Cracked software for the BERNINA ARTISTA 180 that I can copy for you for $200, which you don't need a dongle for. Email me on: [email protected] I have a BERNINA ARTISTA 180 as well and this is the software I run. RRP for the VERSION 3 and the CPS software is $4500.00. Thanks. Lawrence
8helpful
4answers
Dongle issue
The Designer SE software does not use a dongle. If you are attempting a "Smart Update" on the Designer SE and it asks if you use a dongle, just say no and the update on the machine will run.
If you have 3D or 4D software, it uses the dongle and it will be USB. Download the latest driver for your software from the Husqvarna Viking website. The link is through the homepage at Husqvarnaviking.com/us . Click links on the left side of the screen for 4D Software, Help & Updates, and Other Useful Software at the bottom of the page. This will have the latest 3D driver. 4D will require the latest update to the software and a firmware upgrade to the dongle. Run Smart Update on the software and then get the firmware update that is directly below the 3D HASP driver on the Other Useful Software page.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
