Question about Maytag Refrigerators
Loud Bang bottom freezer Maytag refrigerator
Loud bang preceded by loud popping noises
Jorge Rendon
  • Maytag Master
  • 5,420 Answers
Sounds like blown relay in compressor?
Posted on Mar 13, 2015
Heard loud bang and now no power
About 745,000 results (1.02 seconds) Search Results
    Loud bang and loss of power - Ford Truck Enthusiasts Forums
    www.ford-trucks.com > ... > Diesel > 6.0L Power Stroke Diesel
    Dec 11, 2004 - Loud bang and loss of power 6.0L Power Stroke Diesel. ... No matter how much throttle you give it, it won't accelerate. If you get to 2200-2300 ... 4r100 loud bang then nothing
    Jun 16, 2012
    loud pop no turbo boost
    Aug 13, 2011
    LOUD pop, no power, no boost!! Now what?
    Nov 9, 2008
    Loud bang when I tried to enguage 4 wheel drive. Now 4x4 wont ...
    Feb 25, 2007
    More results from www.ford-trucks.com
    loud bang while in 4wheel drive now 4wheel no ... - CarGurus
    www.cargurus.com > Questions > Ford > F-250 Super Duty
    CarGurusDec 1, 2014 - 10 mph a very loud snap bang from under the cab (I think) now... ...Could probably hear it from 50 to 75 ... truck - no cut wires - i have no power to my 4 wheel drive button on the inside of my truck ? any ... Used Cars For Sale.
Jan 29, 2016 | Cars & Trucks
I just had a new COZY L.P. GAS CDV336C installed... Every few minutes it makes a loud bang noise...It then makes pinging noises that gradually fade out...This happens 2-4 times every hour. The bang is loud...
Hi Loretta:
I'd contact the installer. This sounds as if there may be a slow leak. When the gas concentration is high enough it will ignite which would be the bang that you hear. The popping sound could be the flame at the leak source point re-igniting for a few times.
DEFINITELY CONTACT YOUR INSTALLER OR GAS INSPECTOR. THIS IS A SAFETY HAZARD.
Mar 11, 2015 | Dryers
Hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
Mar 25, 2013 | Hotpoint Refrigerators
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Kenmore elite refrigerator/freezer loud banging
it is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Mar 07, 2009 | Kenmore Refrigerators
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Loud banging noise
some popping noise is normal but if it is banging when it stops it needs a new compressor.what has happened is one or more motor mount is broken or weak it could run like this for months or years but it is annoying! if its warranty they have to replace it.
Dec 11, 2007 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
Top Maytag Refrigerators Experts
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
gbob59
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
