Question about Polycom SoundPoint IP 501 IP Phone
How do i update the time from daylight savings?
I am working with a company that has several of these phones. They always update the time automatically. Now, one phone did not after daylight savings time. It is on the same network as several others and they updated. HELP!
David Baglietto
    New Friend:
  • 4 Answers
Double check the sntp setting on the others As see they are using the same server.
Posted on Mar 09, 2015
How do I change time and date on LG440G Tracfone?
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
Mar 09, 2015 | LG Cell Phones
My Nokia E5 is set by default to daylight saving mode, but it is canceled this year in Egypt, so I need to uncheck the auto adjust daylight saving but I cannot.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select OFF, the phone will NOT
automatically update the date and time.
May 22, 2011 | Nokia E5 Cell Phone
I used your instructions to "reset" clock. I did but I have same problem with time. The PROBLEM is how to advance time to adjust to "daylight savings time"? Roy
The phone should automatically adjust to daylight savings time when the phone is powered off then back on again. As the phone reboots, it reconnects to the cell carrier's servers and requests the local time. The server's should have already accounted for daylight savings time, therefore, giving the correct time to your phone.
Mar 13, 2011 | Cell Phones
How do I set my clock ?
Most cell phones will automatically update themselves for time changes, such as traveling to a different time zone or for daylight savings. If your phone does not automatically adjust itself, try turning it off and turning it back on. This will force it to reconnect and check it's time with the cell providers servers.
Time change
With some of the cell phones, you need to make sure that DST (Daylight Savings Time) is turned ON. You should go into your menu, find the clock settings (or World Clock, in some instances) and make sure DST is turned on.
Mar 10, 2008 | Cell Phones
Disable Calendar
The Settings menu provides you with various setting
options to customise the phone to your preferences
and needs. You can also reset the settings to their
default values.
To access this menu, press <Menu> in Idle mode and
select Settings.
Time and date (Menu 9.1)
Use this menu to set the current time and date on
your phone.
Home zone: set the home time zone. Select the
city that corresponds to your home zone. To set
daylight saving time, select Set daylight saving
time
Time: enter the current time.
AM/PM: select AM or PM in 12-hour time format.
Time format: select the time format.
Date: enter the current date.
Date format: select the date format.
Auto update: activate the auto time update
feature. Your phone will read the MCC (Mobile
Country Code) from the network and automatically
update the current time for the country that you
are in when you travel abroad.
Feb 20, 2008 | Samsung SGH-D900 Cellular Phone
Update time
try *2767*3855# after the phone reboots then adjust the daylight saving time. this process should correct the problem you are having.
Nov 04, 2007 | Samsung SCH-u340 Cellular Phone
My time doesnt change at daylight savings time
Go to settings,initial setup,time and date. change it to "off" on autoupdate.You'll get more options. You can change the date and time then.
Nov 04, 2007 | Motorola Mobility RAZR V3
Change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Oct 29, 2007 | Panasonic KX-T7633 Corded Phone
Polycom SoundPoint IP 501 IP Phone Logo
311 people viewed this question
Top Polycom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Darren  Means
Darren Means
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
