The cradle connects to the cigarette lighter connection for power. There is a connection for the Magnet mount antenna which sticks to the roof. The radio can output a radio frequency signal which you can tune your fm radio to receive. It has a number of frequencies to choose from so you can try to find one that is quiet and works best.
There was a car kit and a boom box that were made for the sir-pnp3. I do have both. It allows one to move the radio from the car to a home.
Search for the sir ck3 adapter. It is available on amazon. http://www.amazon.com/Audiovox-SIR-CK3-SIR-PNP3-Satellite-Receiver/dp/B0006FZYJ6
I heard these have a common problem with the antenna line breaking within the radio. I had it happen and replaced the radio. It's a shame since I'm sure I could have fixed it. I think it happens if the radio ends up hanging from the antenna lead. Any electronic tech or engineer should be able to check continuity from the antenna jack and find/fix it.
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Looks like people are selling them on ebay for about $7.
http://www.ebay.com/itm/Car-Power-Adapter-for-Sirius-Audiovox-SIR-PNP3-SIRCK3-SIR-CK3-Satellite-Radio-/200849636300
The tuner is bad. The antenna miniport on your tuner has either a broken or cold solder joint and therefore will not receive. If it's under warranty, they will replace it, if not, you can buy the tuner re-built on Ebay for around 50.00 and is better than new. Hope this helps
